Grabber Posted November 26, 2012 Report Share Posted November 26, 2012 2011-2013 Mustang TSB 12-11-12 INTERMITTENT NO START AND/OR ROUGH RUNNING - BLOWN FUSE 13 - DTC P0627 ISSUE: Some 2011-2013 Mustangs vehicles may exhibit an intermittent drivability condition, crank/no start, a blown fuse 13 in the battery junction box and may have Diagnostic Trouble Code (DTC) P0627 stored in the Powertrain Control Module (PCM). Tried to up load the TSB file but TS has restricted the size of the documents that can be uploaded. Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 26, 2012 Author Report Share Posted November 26, 2012 FORD: 2011-2013 Mustang ISSUE: Some 2011-2013 Mustangs vehicles may exhibit an intermittent drivability condition, crank/no start, a blown fuse 13 in the battery junction box and may have Diagnostic Trouble Code (DTC) P0627 stored in the Powertrain Control Module (PCM). ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Remove the rear seat cushion. Refer to Workshop Manual (WSM), Section 501-10. Inspect the fuel pump module wire harness for a chafing. Is chafing found? (Figure 1) Figure 1 - Article 12-11-12 No - this article does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis. Yes - repair the wiring harness. Refer to the Wiring Diagram (WD), Section 5. [*]Route the harness so that it will lie in the recess area of the rear seat when the seat cushion is installed. (Figure 2) Figure 2 - Article 12-11-12 [*]Install the rear seat cushion. Refer to WSM, Section 201-10. Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 26, 2012 Author Report Share Posted November 26, 2012 The issue is that the rear seat cushion is sitting right down on top of the wire harness to the fuel pump in some cars and the harness gets worn out. The harness needs to be replaced and the new one is routed in the recessed spot in front of the cushion. The TSB pdf has nice photos. I will see if Robert land can fix the PDF up load. Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 26, 2012 Author Report Share Posted November 26, 2012 This photo show where the rear seat smashes the wire harness. This photos shows where to rout the new harness so it does not get smashed. Quote Link to comment Share on other sites More sharing options...
FordRocks1 Posted November 27, 2012 Report Share Posted November 27, 2012 Not that I own a GT500 but its always nice to see Grabber handing a helping hand on TSB's. thanks for posting. Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 27, 2012 Author Report Share Posted November 27, 2012 Not that I own a GT500 but its always nice to see Grabber handing a helping hand on TSB's. thanks for posting. This one is for all Mustangs 2011 - 2013 and 500's from what I can see. Quote Link to comment Share on other sites More sharing options...
SoCalSGT Posted November 27, 2012 Report Share Posted November 27, 2012 Thank you, Grabber....always appreciated. John Quote Link to comment Share on other sites More sharing options...
