Question , on Shelby Aluminum GT500 Race Oil Pan , fit 4.6 Motor ?
Hello All ,,, does anyone know if the " Shelby Aluminum 7 Quart Race Baffled oil pan " , will fit a 2007 - 4.6 GT engine ,,looks to me the have the same number of bolt holds and same bolt pattern ,,, Shelby product code # S7MR-6675-C ,, which sells for $ 619.99 ,,, :camera: ,,,,,this one ,, S7MR-6675-C-2T.jpg .,,, will the stock 4.6 GT - oil pickup tube work ,,will the stock oil pickup tube fit inside ? ,,,,, Thanks for any replies ,,,,Respectfully Richard . :salute:
I bought Moroso Part # 18546 (4.6L/5.4L 7 qt Deep Sump Oil Pan) and it works for both just be careful and making sure the pick up height is adjusted correctly
This appears to be made by Canton part # 13-784A which according to Canton works for both engines
When you do an oil change don't forget it takes an extra quart
Andrew
Andrew
,,,Thanks ,, :salute:
