Snoopy49 Posted October 28, 2012 Report Share Posted October 28, 2012 (edited) I am thinking about going with Michelin Pilot Super Sport 285/35ZR20 on all 4 corners with a set of 20x10" New Alcoa's. Any downside effects? I would like the to be able to rotate the tires, but I don't want to sacrifice performance or drivability. 2013 GT500 Please let me know what you think. Edited October 28, 2012 by Snoopy49 Quote Link to comment Share on other sites More sharing options...
LuckySnake Posted October 28, 2012 Report Share Posted October 28, 2012 I am thinking about going with Michelin Pilot Super Sport 285/35ZR20 on all 4 corners with a set of 20x10" New Alcoa's. Any downside effects? I would like the to be able to rotate the tires, but I don't want to sacrifice performance or drivability. 2013 GT500 Please let me know what you think. I like the 285/35ZR20 as well, but will buy the 265/35ZR20's for the fronts as I ordered a mixed set. I'm not sure why Shelby recommends 275/35ZR20 for the 10" rim? Quote Link to comment Share on other sites More sharing options...
frank bullitt Posted October 28, 2012 Report Share Posted October 28, 2012 I've heard the 285's will rub on the front. 275's seem to be the safest up front on a 10 rim. Some also think a 275 on a 10' rim is better than a 275 on a 9' rim. I ordered all 10's as well. Thinking of 275 on the front and 295's on the back. I'm also considering 275's all around. A few have commented that the same tire size front and back will negatively affect performance. Quote Link to comment Share on other sites More sharing options...
HyperStangs Posted October 28, 2012 Report Share Posted October 28, 2012 Personally I would NOT go 285's all the way around. The only upside would be the ability to rotate, but you would have to unmount the tires to really make it worth your time.... if even then. Also, there is a performance issue. There's a reason why even Ford staggers fronts/rears. Without going into the long and short of it, the car will handle better. The negatives of a matched set outweigh the positives on all counts.... Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted October 28, 2012 Author Report Share Posted October 28, 2012 I don't understand the need for the factory staggering other than as a marketing tool. Unless there is a performance/handling advantage? Example: Factory 19" & 20" 265-40-19 tire = 27.35" dia. 10.43" wide 285-35-20 tire = 27.85" dia. 11.22" wide Ride height difference between front and rear tire is on 1/4" Alcoa 20" 275-35-20 tire = 27.58" dia. 10.83" wide 295-35-20 tire = 28.13" dia. 11.61" wide Ride height difference between front and rear tire is about 3/8" Quote Link to comment Share on other sites More sharing options...
HyperStangs Posted October 28, 2012 Report Share Posted October 28, 2012 I don't understand the need for the factory staggering other than as a marketing tool. Unless there is a performance/handling advantage? Example: Factory 19" & 20" 265-40-19 tire = 27.35" dia. 10.43" wide 285-35-20 tire = 27.85" dia. 11.22" wide Ride height difference between front and rear tire is on 1/4" Alcoa 20" 275-35-20 tire = 27.58" dia. 10.83" wide 295-35-20 tire = 28.13" dia. 11.61" wide Ride height difference between front and rear tire is about 3/8" The principle reason for a staggered setup is to avoid snap-oversteer situations, which are MORE common on cars with matched tires. Basically you're putting the same size tire patch at all four corners with a matched set, on a car that has a biased weight setup (not 50/50 weight front/back). A car with staggered tires is designed with a natural understeer, which is both predictable and controllable. A car with matched tires CAN have a tendency to go from a controlled understeer all the way to a snap-oversteer in the blink of an eye. Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted October 28, 2012 Author Report Share Posted October 28, 2012 So contact area has more to do with the potential problems rather than the diameter of the tire? Quote Link to comment Share on other sites More sharing options...
HyperStangs Posted October 29, 2012 Report Share Posted October 29, 2012 So contact area has more to do with the potential problems rather than the diameter of the tire? Its all about physics... and its always a compromise. Drag, weight, friction, rolling resistance... absolutely nothing is absolute. Getting a car how you like it is difficult enough when you're really pushing it to its limits. Whats BEST to do is use the information that other's have, and to work WITH the laws of physics. As it pertains to the subject started by the OP, I'm only relating what is by all accounts "common knowledge", used by the manufacturers and by those who regularly push their vehicles to their limits (since that's the only time it really comes into play). Having said that, if you drive the streets of Anytown USA like a reasonable person there's no reason you should be concerned with any of this tire talk, save for if they fit. But, if you have ever seen a car go through a corner hard, and suddenly the rear end comes around like something broke you have just witnessed snap-oversteer, and that's not something you want to have happen on the track or the street. Quote Link to comment Share on other sites More sharing options...
