brands5.0 Posted April 23, 2007 Report Share Posted April 23, 2007 Went to the track staterday just to play around. Mods are Evo stage 2 with stock Goodyears out back . Made 3 passes turns out the 1st one was the best 60'.....1.996 330'....5.261 1/8......7.896 mph......96.11 1000'...10.137 1/4.......12.024 MPH.....119.89 I do spend a lot of time at the track with my 95 mustang but it has a C4 with a trans brake and dead hooks every time with 60' in the 1.30-1.39 range. So driving a stick shift car down the strip is new to me. But i hope to brake into the 11's on the stock goodyears next weekend. Link to comment Share on other sites More sharing options...
mach1fever Posted April 23, 2007 Report Share Posted April 23, 2007 1.99 60 is not bad. Do you have any suspension mods besides the springs? Link to comment Share on other sites More sharing options...
brands5.0 Posted April 23, 2007 Author Report Share Posted April 23, 2007 Just steeda lowering springs Link to comment Share on other sites More sharing options...
mach1fever Posted April 23, 2007 Report Share Posted April 23, 2007 Lca's will help. Are you powershifting? Dr's will definately get you in the 11's. Your obviously not blowing the tires off the line so I assume your slipping the clutch instead of dropping it. What rpm are you launching? Link to comment Share on other sites More sharing options...
dgussin1 Posted April 23, 2007 Report Share Posted April 23, 2007 Lca's will help. Are you powershifting? Dr's will definately get you in the 11's. Your obviously not blowing the tires off the line so I assume your slipping the clutch instead of dropping it. What rpm are you launching? your run looks fine up until the 1/4 mile. are you staying in 3rd? are you sure you're in the gas the whole way. My best pass on street tires looks like this; as you can see they aren't much different. pulley 1.911 5.175 7.789 96.52 10.002 11.863 125.26 stock pulley 1.806 5.062 7.704 93.61 9.980 11.896 117.89 Link to comment Share on other sites More sharing options...
brands5.0 Posted April 23, 2007 Author Report Share Posted April 23, 2007 all my runs were shifting into 4th about 1200' out at near 6k. There is a lot of time left in my shifting i will run high 11 on stock Goodyear that was my 1st pass. that pass was 2500 rpm soomth letting out the clutch , next run was 2500 dump the car boged but still went 1.99. last run was 3000 dump and spin city. So it seems the 3rd to 4th shift if hurting my mph some Do you finish in 3rd? or do you make the 3-4 shift Link to comment Share on other sites More sharing options...
brands5.0 Posted April 23, 2007 Author Report Share Posted April 23, 2007 Dgussin1 our 1/8 mile time is right there. mine 96.11 mph yours 96.52 mph which seems right because i was in 2nd gear untill around 6300. 3gear around 6000. and thru the traps in 4th. So by staying in 3rd that might get me in the 11's right there Link to comment Share on other sites More sharing options...
dgussin1 Posted April 23, 2007 Report Share Posted April 23, 2007 I have 3.73's...so I am in 4th at around 104-106 mph. Link to comment Share on other sites More sharing options...
mach1fever Posted April 24, 2007 Report Share Posted April 24, 2007 In my mach I was running through the traps in the top of third at 6250 through the traps. Those 3.73's are going to make you shift into fourth where you will definately lose mph, even speed shifting. I would try power shifting a little earlier in third to get it in the power band and pulling in fourth. Link to comment Share on other sites More sharing options...
brands5.0 Posted April 24, 2007 Author Report Share Posted April 24, 2007 I am still running the stock gears Link to comment Share on other sites More sharing options...
LuckySnake Posted April 24, 2007 Report Share Posted April 24, 2007 I am still running the stock gears I haven't heard of anyone going 11's with stock tires, if you do this you might have some kind of record? Link to comment Share on other sites More sharing options...
LuckySnake Posted April 24, 2007 Report Share Posted April 24, 2007 your run looks fine up until the 1/4 mile. are you staying in 3rd? are you sure you're in the gas the whole way. My best pass on street tires looks like this; as you can see they aren't much different. pulley 1.911 5.175 7.789 96.52 10.002 11.863 125.26 stock pulley 1.806 5.062 7.704 93.61 9.980 11.896 117.89 When you say street tires, do you mean DR's or the tires that came on the car new? Thanks Link to comment Share on other sites More sharing options...
dgussin1 Posted April 24, 2007 Report Share Posted April 24, 2007 When you say street tires, do you mean DR's or the tires that came on the car new? Thanks On the stock pulley run I believe I was running the factory tires. On the Pulley pass I was running my 19x11 CCW's with 295/35 bfg kdw2's (not drag radials). Link to comment Share on other sites More sharing options...
brands5.0 Posted April 24, 2007 Author Report Share Posted April 24, 2007 so far mine still has the stock goodyears. 11 soon to come Link to comment Share on other sites More sharing options...
mach1fever Posted April 24, 2007 Report Share Posted April 24, 2007 Are you holding third then? Roger Link to comment Share on other sites More sharing options...
