GT500 spoiler with rear-view / back-up Camera
You guys can get an easy plug and play license plate camera at nav tv.com. I just installed it this a couple days ago works perfect. You can't have a rear view camera in the spoiler otherwise it would be pointing in the ground. And I installed this camera without havnig to take my back seats out or anything. It was so easy to run the wire through and under the side of the carpet.
  • 2 weeks later...
My SGT's camera is next to my license plate light. Perfect. Low profile, and easy to install (since the light is there, there is a pass-through you can use for the camera wires, just Dremel a little notch off of the light's square hole for clearance).
Jer
  • 1 month later...
Jer
Jer
Can you post some pictures of it?
  • 2 years later...
Shelby had to remove the GT spoiler with camera to put the 500 spoiler on. They laid the factory camera in the car. I called a specialty house when I got the car home. They wanted $400 to install a new camera. I have NAV so I don't need the screen or wiring. They want to put a whole new system in. Can the camera be removed from the factory mount in the GT spoiler and remounted? Anyone try this?
  • 2 years later...
You should be able to mount the Camera any where you want.
