Spare tire insall =07SGT5466
6f09
I installed a spare tire-jack-lug wrench w/holder-instructions f/2007 Mustang GT.$175.oo(junkyard).
Drove it a mile and did "figure eights" with it.With the spare on the front.& back.
NO PROBLEMS!
Jack clearence (w/tire deflated) minus 3-3/8" for side wall
Front = minus 3/16"
Rear = minus 3/8"
need 2"x4"x6" wood to drive up on, to rase the car for Jack clearence.
Tire sizes.
stock = R235/50-18 = 26-1/2" tall. BFG
spare = T155/70-17 = 25-3/4" tall Matrex
Wheel well lip to ground measurment.
stock spare no tire
FRONT 27-13/16" 26-7/8" 24-5/8" = Jack down rotor 1-1/2" f/ground
REAR 28-1/8" 27-3/4" 25-1/8" = Jack down shock bracket on ground.
I feel safer with a spare instead of the fix-a-fat
GOD Bless
Jim
07SGT5466.
i wouldn't drive far with a spare on the back. can ruin the the differential
definitely good work though. ive thought about putting a spare in. just never seem to get around to it lol
As long as you don't drive fast OR a long distance, you'll be fine with the size difference. Remember: 50/50 Not over 50 mph and not over 50 miles! That's why it's for emergency use only!
Sam
I don't have any experience with the stock Ford jack included with the Mustang GT spare, but I know that using a floor jack on the front jacking point will raise a rear tire off the ground far enough to get both wheels off. if long-distance travel on the "compact spare" is inevitable a useful front could be switched to the back.
That clearance-for-the-jack-when-a-tire-is-flat problem is very real. A piece of two-by-four might be sufficient, but I have a tapered section of four-by-four I carry on long jaunts through empty countryside..
Here is what I carry in the trunk to place under the tire to help get the car raised so the jack will fit. It is a pair of 2"X8" pine glued together. The extra 4" can make the difference in fitting the jack properly so it will raise the car.
thanks for the info I am going to add anouther 2x4x6" board for more hight , as of now (1) 2x4x6"fix under the apare between the jack .
GOD Bless
Jim 07SGT5466
A 235/50/18 will fit, kind of. Its real snug and the carpet will not lay flat. If the tire is under 26" tall and less than 9" wide I think it will fit with no issues. The 235 is 27" tall and over 9" wide.
The OE spar is ~25.5" tall and ~4.25" wide.
