djfollmann Posted June 6, 2012 Report Share Posted June 6, 2012 Sometimes when we puill up to a stop light or sign our car will dye on us. We are able to start it right back up, but this may happen two or three times in a night when we are driving it. We wonder if this happened to any of you with your GT 350 car??? Quote Link to comment Share on other sites More sharing options...
Helix Posted June 6, 2012 Report Share Posted June 6, 2012 Sorry to hear; can't say I know the solution, but if I can borrow your thread :P My lincoln (rarely) will die when I put the car in reverse to back it into the garage. Same thing: it starts right back up. Quote Link to comment Share on other sites More sharing options...
swa737 Posted June 6, 2012 Report Share Posted June 6, 2012 When mine was brand new, it did this twice. Hasn't done it since and that's been a little over a year ago. Are you running high octane gas? Quote Link to comment Share on other sites More sharing options...
djfollmann Posted June 6, 2012 Author Report Share Posted June 6, 2012 We are running 91 Octane BP - this is what it was tuned for. Quote Link to comment Share on other sites More sharing options...
tony356 Posted June 6, 2012 Report Share Posted June 6, 2012 i have this issue only when first starting the car. after it is warm it is fine. i use 93 octane and splash in 100 octane when i can. what hp do you have? Quote Link to comment Share on other sites More sharing options...
gators196 Posted June 6, 2012 Report Share Posted June 6, 2012 Happened to me twice now since I took possession last July. Did not happen last year. Both times in the last month. I have 624 HP. No mods installed after delivery. Quote Link to comment Share on other sites More sharing options...
Torch40 Posted June 6, 2012 Report Share Posted June 6, 2012 Two or three times a night is not normal. Quote Link to comment Share on other sites More sharing options...
NJPat Posted June 6, 2012 Report Share Posted June 6, 2012 i have this issue only when first starting the car. after it is warm it is fine. i use 93 octane and splash in 100 octane when i can. what hp do you have? i run the same gas as Tony, and have the same issues when cold or right after a start - car can stall. that, and i just failed inspection here in NJ for "not ready" O2 sensors! waiting for SA to come up with a solution - fast Pat Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted June 6, 2012 Report Share Posted June 6, 2012 Sometimes when we puill up to a stop light or sign our car will dye on us. We are able to start it right back up, but this may happen two or three times in a night when we are driving it. We wonder if this happened to any of you with your GT 350 car??? I've seen this sympton often on a car with a dirty throttle body. The throttle blade is open enough for minimum air flow but gas coking builds up at the blade and closes it off. The cure is a rag with carb cleaner on it. Open the throttle blade and stick the rag in, wipe it all around the body AND the edge of the blade. Done. Try it and see if that cures it. If not, do you have the EGO sensor code too? Phill Quote Link to comment Share on other sites More sharing options...
RogerS Posted June 6, 2012 Report Share Posted June 6, 2012 When modifying any of the new PCM's cars need to go through a re-learn cycle. This can be affected by battery run down, where charging needs to take place or when jump starting due to the same condition. It is recommended, by Ford Racing, not to utilize a jump box but to bring the battery up to charge with a trickle charger. If the vehicle has not been driven much this re-learn can take several drives, starts and key "on-off" cycles. There is no set number. Did you use stabilizer while in storage? How long was your car in storage? Have you checked with your RI dealer? Let us know if you need assistance. Roger Quote Link to comment Share on other sites More sharing options...
gators196 Posted June 6, 2012 Report Share Posted June 6, 2012 Thanks Roger. I have had this happen just a couple of times so I have not brought it into the dealer. I did use stabilizer and stored from December thru early march. However, because we had such a warm winter with hardly any snow I was able to get it out a few times. I did not use any charging devices. Thanks for the tips. Quote Link to comment Share on other sites More sharing options...
tony356 Posted June 6, 2012 Report Share Posted June 6, 2012 i run the same gas as Tony, and have the same issues when cold or right after a start - car can stall. that, and i just failed inspection here in NJ for "not ready" O2 sensors! waiting for SA to come up with a solution - fast Pat Good luck with SA greeting you a solution to pass emissions. Mine was never ready even with SA , the dealer and ford racing involved. Now I I have to limit my milage to under 5k per year to be exempt in pa. I had the same not ready problem. Quote Link to comment Share on other sites More sharing options...
tony356 Posted June 6, 2012 Report Share Posted June 6, 2012 When modifying any of the new PCM's cars need to go through a re-learn cycle. This can be affected by battery run down, where charging needs to take place or when jump starting due to the same condition. It is recommended, by Ford Racing, not to utilize a jump box but to bring the battery up to charge with a trickle charger. If the vehicle has not been driven much this re-learn can take several drives, starts and key "on-off" cycles. There is no set number. Did you use stabilizer while in storage? How long was your car in storage? Have you checked with your RI dealer? Let us know if you need assistance. Roger Today's gasoline sucks! Use the best gas with the highest octane you can. If you have any stations that have ethanol free gas, use it! If not try and put some race fuel in the car when possible. In addition, drive as much as you can and always fill the tank when u think u might not drive it for a week or more. Use marine stabilizer for the gas. I use it all year long and will also use techron fuel system cleaner one a month. Quote Link to comment Share on other sites More sharing options...
djfollmann Posted June 7, 2012 Author Report Share Posted June 7, 2012 My car is a 624 horse with tuned to 91% octane. I talked to Craig at Shelby American and he said I should stay with 91% octane because that is where the tune was set. He suggested unhooking the battery for 24 hours and then hooking it back up. Something about learning my driving habits. It was stored all winter in a heated garage - no stabilizer added and I had a charger on it that would just keep it charged up every so often Thanks everyone for all of the help and suggestions it just bugs me that it does this from time to time. I would clean the throttle body, but I do not know where it is or what it looks like. Any suggestions?? This spring when I started it - it could not have started any quicker - just started right up! Thanks to Shelby American for the "built information" on the 2011 GT350. I absolutely love the car and it just bugs the heck out of me when it does that. Quote Link to comment Share on other sites More sharing options...
NJPat Posted June 7, 2012 Report Share Posted June 7, 2012 Good luck with SA greeting you a solution to pass emissions. Mine was never ready even with SA , the dealer and ford racing involved. Now I I have to limit my milage to under 5k per year to be exempt in pa. I had the same not ready problem. Tony- unfortunately, I need to pass inspection in NJ Roger- do you hear these issues? It's been a week but no response from Gil at the Speed Shop. That is an unacceptable condition on a car that cost over $100k and was "custom tuned" at the Speed Shop. Do I speak with you, Gary P or Gary D to resolve this and get my car back on the road? Pat Quote Link to comment Share on other sites More sharing options...
nwdriver Posted June 7, 2012 Report Share Posted June 7, 2012 My 2011 GT350 has died twice going over the same speed bump, but in different directions. Quote Link to comment Share on other sites More sharing options...
RogerS Posted June 7, 2012 Report Share Posted June 7, 2012 Tony- unfortunately, I need to pass inspection in NJ Roger- do you hear these issues? It's been a week but no response from Gil at the Speed Shop. That is an unacceptable condition on a car that cost over $100k and was "custom tuned" at the Speed Shop. Do I speak with you, Gary P or Gary D to resolve this and get my car back on the road? Pat Stated above to contact me Pat. 702-942-7324 ext. 145. But you did speak with Frankie yesterday around noon our time correct? Roger Quote Link to comment Share on other sites More sharing options...
07gt500conv Posted June 7, 2012 Report Share Posted June 7, 2012 Today's gasoline sucks! Use the best gas with the highest octane you can. If you have any stations that have ethanol free gas, use it! If not try and put some race fuel in the car when possible. In addition, drive as much as you can and always fill the tank when u think u might not drive it for a week or more. Use marine stabilizer for the gas. I use it all year long and will also use techron fuel system cleaner one a month. I totally agree with you. Today's gas sucks. I am fortunate to have a station about 20 miles away with REAL gas. My 71 Bronco and 2003 Ford F450 MH has had issues with ethanol because they sit too much. Switched to REAL gas and the issues went away. I drive the Shelby enough that I have not seen the issues, but it it starts will make the trip to the REAL gas station. Quote Link to comment Share on other sites More sharing options...
NJPat Posted June 7, 2012 Report Share Posted June 7, 2012 Stated above to contact me Pat. 702-942-7324 ext. 145. But you did speak with Frankie yesterday around noon our time correct? Roger Roger- I did hear from Frankie. They are reportedly working on a solution. Hopefully, by tomorrow they will have it. Failing which, i have to go to DMV for re-inpection with no solution and will no doubt fail again. At that point, what do we (aka I) do? thanks for SA's anticipated assistance. Pat Quote Link to comment Share on other sites More sharing options...
NJPat Posted July 13, 2012 Report Share Posted July 13, 2012 PROBLEM SOLVED Simply have Jon Lund tune your GT350 No stalling; runs better And now I've passed New Jersey motor vehicle inspection It's a beautiful thing!! Quote Link to comment Share on other sites More sharing options...
gators196 Posted July 13, 2012 Report Share Posted July 13, 2012 Did he tune it remotely or was this done with a handheld? What was your before and after dyno results? Thanks Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted July 13, 2012 Report Share Posted July 13, 2012 PROBLEM SOLVED Simply have Jon Lund tune your GT350 Who tuned it originally, with what tune? I would suspect it was a Ford Racing 50-State legal tune that Shelby installed? Is yours supercharged or naturally asperated? Phill Quote Link to comment Share on other sites More sharing options...
NJPat Posted July 13, 2012 Report Share Posted July 13, 2012 The car started life as an R tune the Speed Shop installed the JLT and Headers, and then custom tuned the car on the Speed Shop's Dynojet (STD - whatever that means) and at 75 degrees in February the car posted 565 and then 563 at rear wheels after Jon tuned the car (in 105 degree heat here in NJ and after the intercooler fans didn't work due to some glitch - boy the car was HOT!) the car posted slightly better numbers on Evolution Performance's Mustang Dyno (SAE - whatever that means, but i'm told it's 4% or more lower reading than a Dyno Jet, and that was before the "heat" issues and non-functional intercooler). either way, car drives better and feels even more peppy than before - if that's possible! kudos to Jon for braving the heat on a Saturday (his birthday, to boot) to help me, and to Fred Cook at Evolution for setting things up and dealing with the intercooler (and other) issues with the car also, Frankie Montrone and Gary DAvis from SAI were SUPER too - they permitted Evolution and Jon Lund to get involved, and even covered the cost!! can't thank all those guys enough - it's like driving a completely different car now. again, thanks to ALL who helped me though this! Pat Quote Link to comment Share on other sites More sharing options...
DutchGT500 Posted July 27, 2012 Report Share Posted July 27, 2012 That is really good of SAI to let John Lund fix it. Quote Link to comment Share on other sites More sharing options...
