73mockone Posted May 17, 2012 Report Share Posted May 17, 2012 I'm installing Ford Racing Autometer electric, water temperature and voltmeter gauges in an SOS A-pillar pod. What is the best location to pull power for the gauges? Also, the gauge lights needs to be run to a keyed power source. Any suggestions for the best location? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted May 19, 2012 Report Share Posted May 19, 2012 I ran my power off the harness from under the steering column. I used a test light for key on key off but can't remember which wire and if the wiring schematic was used. I used the ground that was there on the kick panel Good luck Quote Link to comment Share on other sites More sharing options...
