stephenroy Posted May 14, 2012 Report Share Posted May 14, 2012 I like to take my car out to Shelby events and some local events and run it around the track a few times. I have noticed that on our local track in Fontana CA, that i get fluid coming out of the transmission and the differential over flow tubes. My initial reaction is to replace the fluid with higher temp fluid. Any thoughts out there. Quote Link to comment Share on other sites More sharing options...
hotrodric Posted May 15, 2012 Report Share Posted May 15, 2012 There are some after market catch cans out there. Also Ford had a TSB a couple of years back to correct this. It was a new part to replace the vent. It has a small rubber bulb that collected the oil. If you are still under warranty you may be able to still get the part. Quote Link to comment Share on other sites More sharing options...
09 Red GT500 Posted May 19, 2012 Report Share Posted May 19, 2012 I don't know about the transmission, but Bob's Auto Sports has a catch can for the differential. It is very similar to the KR catch can which is no longer available. Quote Link to comment Share on other sites More sharing options...
Slabo Posted May 19, 2012 Report Share Posted May 19, 2012 Not uncommon for the diff. to overflow. As mentioned install the catch can or the little rubber bulb for the diff. As for the trans I think it is uncommon for it to overflow. Perhaps it was overfilled? Check the level. Should be fill to spill when the car is perfectly level. Best way is a level 4 post lift. You can check the diff level as well. Many also fill to spill on the diff but the correct level is actually 1/4-1/2" below the front fill hole. Again when the car is level on its own suspension. Quote Link to comment Share on other sites More sharing options...
stephenroy Posted June 1, 2012 Author Report Share Posted June 1, 2012 Thank you for the help. I will get the catch can ordered up. As far as the trans goes, i'm going to try a higher temp fluid and see if that helps. Everything else about the car is set up just like I want it. Thanks again. Quote Link to comment Share on other sites More sharing options...
