Engine bay cleaning time
SGT0225
I use Optimum Power Clean. Dilute or use full-strength. Works pretty well.
BTW, Simple Green is mighty good for cheap.
Jer
Simple green is a great degreaser/cleaner... But once it is clean. I use Adams Super Vinyl and Rubber Treatment and Adams In and Out spray to hit the impossible to reach area's.
I drove across country to the 50th bash. Ask anyone who knows me on the forum. My engine bay is prestine. And I have 32k on the car. Here are the befores and after videos of my engine bay.
Here's my engine bay before the trip.
Here it is after the trip... 6,180 miles through snow, rain and sandstorms. Skip to the 1 minute mark to miss all the bug guts on the car! And then watch the next minute or so.
See post below for after trip cleaning with products mentioned...
Here's what it looked like after using the products mentioned.
Here's a link to the Adams forum with a video on how to. It's worth the time to watch. You don't need to use all Adams products. But the process is the best I've found.
http://www.adamsforums.com/forums/wheels-trim-undercarriage-engine-bay-detailing/8778.htm
I need to spruce mine up a little, esp the spot on the intake where a little mouse apparently camped during the winter months. I don't know how / why he did this as I did check under the hood fairly routinely and even drove the car during the winter a couple of times (on non-treated and dry roads of course).
I checked the rest of the car thouroughly...no other evidence...
Ok guys heres a little trick i use and it works very well for me . firestone makes a spray can of stuff for tires to spay on to make them shine and protects to . I use it on underhood hoses and plastic works out great for car shows.So give it a try and also a can is only like 2.50 a can dave
What prducts work to clean under the hood?
Plastic parts, metal parts, any parts...
S100 Total Cycle Cleaner - available at any Harley Davidson dealer. Available in aerosol or pump spray, spray on the entire engine compartment (when cool), rinse and blow dry. S100 restores metal rubber and plastic to as new condition.
Simple Green is a great cleaner and I use it all the time BUT keep in mind that Simple Green will etch/corrode alumiumn if not diluted properly AND rinsed off right away.
While I haven't tried it Simple Green apparently makes a product called something like, Simple Green Aircraft, that is "safe" for aluminum.
Steve
Sounds like a good idea!
http://www.s100.com/
How do y'all dry if you don't have a compressor??? Just washed under the Hood and really don't wanna try to shammy (spelt wrong I know) all of it lol
On some Shop Vacs you can reverse the hose so it blows the vacs exhaust air out of the hose nozzle. Make sure the Shop Vac is clean with no debris in it and that it has a clean filter.
Steve
Steve
One video says to close the hood after washing the engine bay and start the car. Let it run and generate heat under the hood. I don't know how well that will work, never tried it.
Found a mouse under my hood today. I saw the nest he built a couple weeks ago under the intake which was made from the battery cover insulation. Guess he decided to pay the ultimate price to ride in a Shelby. :hysterical:
Worked good on my wife's car this last week. The fun part was while I was doing the recommended external wash while the engine dried itself, great clouds of steam started coming out from under the car. OMG, now what has happened?
Turns out the garden hose had sprung a leak and was spraying on the exhaust. What a relief.
My shop vac isn't one that can blow :-(. Seems as if you just let the engine heat dry it, it would have water spots afterwards....
I have not washed under my hood yet, I feel the same about the spots.
  • 2 weeks later...
I bought some product from a member on here called show car. This product works excellent. You check out his product at www.showcardetail.com. I personally think It is great product. I work in the automotive aftermarket field and I sell everything and this is hands down the best out there.
