Interior lights color
as far as i can tell you can not, it seems you can only change the guages and the ambient lighting
Yes the door sill colors can be changed. Mine are currently blue. All you have to do is take off your sill plates and just see what connector pin is the blue or green. Then when you get the color you want swap that pin with the red power pin and your good to go. So basically just have to swap the wires, no cutting required. Once I figured that out took like 5 minutes on the other side. Hardest part is getting the door sills off. They just pull off but are just on there really good. So basically the colors you can have you door sills light up are red, blue, or green. Theres four pins in the connector, one for each color and the other is the ground. Now i believe the wires should be marked for which color they are as they were on mine.
THANKS, great info!!
  • 1 month later...
I know im gonna sound stupid here, because i do most of my mods and maintenance myself, but i pulled off the driver side door sil, and i could not figure out what to do without cutting anything. So i just put it back together. I want the SVT in blue to match my Kona... Any pics of what you did once the sill was off? Any help would be greatly appreciated.
Oh, and GREAT color car there bro...
Thx
GUS
Sorry brother get any pics during the install. I was too anxious to hurry up and finish. Honestly it really easy. Just look the white connector and you should see 4 wires I believe, its been awhile. One is ground, and three marked for their certain color. The only one that has power is the wire with the red strip on it. Disconnect the connector that way you can push the wires and their pins out of the connector. So all you have to do is push that wire and the wire with the blue strip out of the connector and swap them. Then it should light up blue. Just take your time and really look at the wires. Once you get the first one figured out the other side will be a breeze.
Again sorry I didn't get pics during the install.
Do you swap the wires on the car side or the sill side? I removed the sill and worked on moving pins on the sill side connector but no go. Pulled out the red lock and all I could seem to do were push them out which doesn"t help. In order to get the wires swapped on this connector means to pull them out which I couldn't seem to do. Help!
After a little searching I found this little article. Hope this helps even more.
This is for 2010+ Mustangs with lighted sill plates.
When you pop your sill plates off you will notice there are only 4 wires.
You disconnect the sill plate pigtail from the body harness.
On the body harness side the wires are color coded.
Yellow = power #1
white/red = red #2
white/green = green #3
white/blue = blue #4
m5lp_1006_14_z+s197_custom_illuminated_sill_plates_light_entertainment+wiring_ha%E2%80%8Brness.jpg
Remove the red clip that has these pins locked in place.
After the red clip is removed use a pic or medium sized needle to push the release clip in on the pin you want moved.
Your yellow wire does not get moved EVER.
Any other wire can be put in the #2 slot. And the wire that is in the #2 slot will be the color you want to change too.
For example if you want your sill plate to light up blue, then the red wire would go to slot #4 and the blue wire will go to slot #2
After you have the pins relocated where you wnat them, put the red locking clip back in your body harness pigtail.
Then plug your sill plate back in and the put the sill plate back in the car.
So finally figured out the pin swap. But when I switch to blue, no light. Nothing. I can get green and of course red but no blue! Swapped into every combination I think. Could it be that I have a bad sill light for blue?
i have the red clip out, I even used a small pair of needle nose pliers to slightly pull on the wires, but no go. While facing the inside of the plug, it almost seems like to need to use a needle or small ice pick to depress the top of the wire and pull from the back.
  • 2 weeks later...
  • 4 weeks later...
Well, get this. I switched the driver's side to be blue but nothing comes on. Green is good. Red is good. Left it configured for blue assuming the light broken but would try the passenger side. Hadn't gotten around to the passenger side yet but took the car out on Sunday and sure enough, the blue SVT comes on. It stays on mostly but does flicker off and on. So its either a bad wire somewhere or the light. Any ideas? Swap it with the passenger side and see if it flickers too? That would at least tell me if its outside of the light and somewhere in the wire.
It may be a bad crimp on the end of the wire. They may have crimped the insulation rather than the bare wire.
Did the wire swap on the passenger side tonight and blue works just fine. Connected the passenger light to the driver side connection and it works just fine. No flickering. Inspected the wires and connections on the driver light. Just fine. What's weird is when the light is vertical, no flickering. Tap, shake, bump.....no flicker. As soon as I place it horizontal for install....flickering starts. It has to be a loose wire in the light. We'll see if it works itself out over the next few weeks. If not, guess I got my first warranty item.
  • 1 month later...
Took the Shelby in recently for the 1-2 shift repair and also had them replace the driver side sill light under warranty. Yesterday took the 10 minutes necessary to swap wires and all is BLUE! No flickering. No problems. Now that I have done the wire swap so many times, this mod is super easy. If anyone needs advice on it, let me know.
I did the swap to blue as well but was not as easy as I thought. My old eyes can't see the small connector very well, but I did it. I had no idea this could be done. Thanks for the post and info, I never really liked the red anyway. All my interior are blue LED.
