Looking for an Oasis report - asap, thanks in advance
uk_samo
--->>Looks like it has the upgraded clutch! Woohoo!
OASIS RESULT: 1ZVHT88S995137160 USA: EN-US 27-APRIL-2012 / 19:41:54 EST/ APP2
Local Time: 27-APRIL-2012 / 4:41:56 PM
  • VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2009 MUSTANG BODY STYLE: SHELBY COUPE ENGINE: 5.4L DOHC 4V EFI SC TRANSMISSION: 6 SPD TREMEC ASM T56 AXLE CODE: CG ENGINE CALIBRATION: 9ZF2SC0A PAINT COLOR: VAPOR SILVER PEARL PAINT CODE: ZY RADIO: AM/FM STR/6CD/NAVIG SYS AXLE RATIO: 3.31 FINAL DRIVE RATIO WHEEL SIZE: 18 X 9.5 ALLOY WHEEL FRONT TIRE: P255/45/R18 F/285/40R18 R ZR18 GROSS VEHICLE WEIGHT: 4700 LB. GVW
  • WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
  • ACCURATE REPAIR NOTIFICATIONS
NO ARN MESSAGES FOUND
  • GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty WARRANTY START DATE: 06-NOVEMBER-2008 BUILD DATE: 13-OCTOBER-2008 SALE MILEAGE: 00007
  • OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
  • EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
  • WARRANTY REPAIR HISTORY
13-JULY-2011 DEALER: Kearny Pearson Ford WARRANTY CLAIM NUMBER: 069388 ODOMETER: 021473M PART NUMBER PART DESCRIPTION
QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC AR3Z 6375A FLYWHEEL ASY 001 100308A 69 FROZEN/SEIZED/BINDING AR3Z 7B546A DISC ASY-CLUTCH 001 F6ZZ 7600A BEARING CLUTCH PILOT 001 AR3Z 7A508A ROD-CL/SLAVE CYL PUS 001 AR3Z 7A512A TUBE ASY-MASTER/SLAV 001 N808969S100 006 F6ZZ 6379AA BOLT-FLYWHEEL TO CRA 003 F6ZZ 6379AA BOLT-FLYWHEEL TO CRA 005 DIAG CONCERN FOUND DAMAGE TO CLUTCH CAUSED BY FLYWHEEL WARPAGE PERFORMED TSB 10-03-08 ROADTESTED ALL OK 21-APRIL-2011 DEALER: Serramonte Ford, Inc. WARRANTY CLAIM NUMBER: 010862 ODOMETER: 020028M PART NUMBER PART DESCRIPTION
QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC 8R3Z63214A62A FILLER DR/WND OPNG 001 B 42 DOES NOT OPERATE PROPERLY CR3Z 6351238A RETAINER - WEATHERST 001 B 000 23943A TECH #60 R&R RIGHT SIDE DOOR UPPER MOULDING. TECH # 60 R&R RIGHT SIDE DOOR W EATHERSTRIP BEHIND RIGHT DOOR MIRROR. TECH #60 R&I RIGHT DOOR INSIDE TRIM P ANEL AND R&I RIGHT DOOR MIRROR. | On-line 1878 END OF OASIS REPORT FOR 1ZVHT88S995137160
© Copyright 2002-2012 Ford Motor Company. All rights reserved.
Thanks for that much appreciated :) It is indeed good news about the flywheel/clutch, however I had previously thought that the build date for the new clutch was around August 08, with this being built in October should have already had the new one. In any case it defiantly does now which I am very happy about, thanks again for running the report.
