CodyWayne718 Posted April 23, 2012 Report Share Posted April 23, 2012 It's in any gear right at 1750rpm. Goes away when I push the clutch in. It almost sounds like plastic on plastic but loud. Is this just normal clutch chatter or should I worry? Link to comment Share on other sites More sharing options...
dbackg Posted April 23, 2012 Report Share Posted April 23, 2012 Throw out bearing? or the clutch plate springs? What year is your Mustang? Link to comment Share on other sites More sharing options...
CodyWayne718 Posted April 23, 2012 Author Report Share Posted April 23, 2012 It's an 07 with 17k miles. I had someone ride with me about a week ago before I pinned exactly where it did it in the rpm range so he didn't get to hear it constantly and it would just be faint when he did hear it. He said gear roll over? I just feel that it shouldn't have this kind of noise coming out of it. Link to comment Share on other sites More sharing options...
dbackg Posted April 23, 2012 Report Share Posted April 23, 2012 Thanks to Grabber, read these threads: http://www.teamshelby.com/forums/index.php/topic/48437-3rd-revision-the-new-revised-clutch-tsb-09-19-11/ http://www.teamshelby.com/forums/index.php/topic/53664-4th-revision-the-new-revised-clutch-tsb-10-3-8/ Link to comment Share on other sites More sharing options...
Robert OHara Posted April 23, 2012 Report Share Posted April 23, 2012 I had that noise, found what it was when I replaced the clutch.. Vent tube on the transmission was cicking on the case. I put a 3 inch piece of rubber hose around it , and it is quiet now. Link to comment Share on other sites More sharing options...
CodyWayne718 Posted April 23, 2012 Author Report Share Posted April 23, 2012 Dbackg, I've read thru that stuff before I joined. I don't think I'm having those symptoms. Just the chatter at a certain rpm. B Shelby, I assume I would have to tear into it in order to see if it was the vent tube? I'm not too mechanically inclined when it gets deep into stuff. Link to comment Share on other sites More sharing options...
dbackg Posted April 23, 2012 Report Share Posted April 23, 2012 Sounds like B Shelby has the answer. I have a lift, drive on over, I am Tempe, AZ. Link to comment Share on other sites More sharing options...
CodyWayne718 Posted April 24, 2012 Author Report Share Posted April 24, 2012 Dbackg, thanks for the offer but I'm in ky. Couldn't figure out how to show my state. Link to comment Share on other sites More sharing options...
Robert OHara Posted April 24, 2012 Report Share Posted April 24, 2012 I 'm in one state North of you, come on up, I have a lift. Link to comment Share on other sites More sharing options...
CodyWayne718 Posted April 25, 2012 Author Report Share Posted April 25, 2012 B, would the noise go away with the clutch pushed in? Thanks for the offer Link to comment Share on other sites More sharing options...
Robert OHara Posted April 25, 2012 Report Share Posted April 25, 2012 Yes ,, It only rattled at certain rpm ,when I shifted or let off the gas and accelerated again Link to comment Share on other sites More sharing options...
