2007_Shelby_GT Posted March 19, 2012 Report Share Posted March 19, 2012 Ever since Sebring last year, my fuel gauge has been acting up - reading empty when full, then jumping to indicate full or reading somewhere between empty and full when you know it's full. As for fueling - she's only taking about 10 gallons or so even though I'm sure it's near empty - not to mention the dreaded micro-speed pump fill routine! Anyone found solutions? - the TSB listed doesn't pertain to 2007 and beyond... Sam Quote Link to comment Share on other sites More sharing options...
JT93 Posted March 20, 2012 Report Share Posted March 20, 2012 I had the same issue after a track day. I disconnected the battery for a while to let the computer reset and the problem was taken care of. Quote Link to comment Share on other sites More sharing options...
ZepDad Posted April 7, 2012 Report Share Posted April 7, 2012 My fuel gauge went out several months ago. Fortunately, I was still under extended warranty. The dealer replaced the fuel sender first, then the fuel pump. That did not correct the problem so they finally replaced the electronic brain. So far it's been working fine. Nearly a $2000 warranty repair. Quote Link to comment Share on other sites More sharing options...
slbgtsc Posted April 7, 2012 Report Share Posted April 7, 2012 Ever since Sebring last year, my fuel gauge has been acting up - reading empty when full, then jumping to indicate full or reading somewhere between empty and full when you know it's full. As for fueling - she's only taking about 10 gallons or so even though I'm sure it's near empty - not to mention the dreaded micro-speed pump fill routine! Anyone found solutions? - the TSB listed doesn't pertain to 2007 and beyond... Sam Sam, In 2009 my fuel gauge started acting similar to what you are describing and Ford fixed it via a TSB on the sending unit in the tank. Mine is a 2007 as well. I would double check the TSB thread. Quote Link to comment Share on other sites More sharing options...
kbvaughn Posted April 9, 2012 Report Share Posted April 9, 2012 I used a techron based cleaner and add fuel with techron now, gauge has been fine since. Quote Link to comment Share on other sites More sharing options...
