Transmission Seal
Changed the oil and I noticed oil seeping from the gasket between the transmission and the bell housing. I'm thinking the slave cylinder is leaking but I stuck my finger in the window of the bell housing and didn't get any fluid on the finger? Anyone else had this issue? Car has 34k on it and I just put a new clutch and slave in it this summer. No shifting issues either?
Thanks
Thanks
That could be a problem you don't want the fluid hit the clutch set up you will be spend some cash to fix it. But is trans fluid of brake fluid either way you need to have it pulled apart. Also check the fluid level in the trans before driving it again
