SGT0128 Posted February 20, 2012 Report Share Posted February 20, 2012 I know this has been beat to death but I'd appriciate your input. I'm looking for personal experencies between the Hot Rod and Comp Mutha Thumpa cam or anyother cams you have used.sucessfully. My warranty expires soon and I'm ready to do this. I don't have any near future plans to add the supercharger but I did add the 4.10 gears. Quote Link to comment Share on other sites More sharing options...
JT93 Posted February 20, 2012 Report Share Posted February 20, 2012 I'm not really sure how much help I will be in making a decision, but here it goes. I have the Hot Rod cams because I had heard them before and then couldn't live without them. I also chose the Hot Rods because they were a Ford Racing part (I always feel better when I know it's a ford part - in some form - in the car). I can't really refute not getting the Thumprs, I haven't heard anything bad about them. Personally I'd go with the Hot Rods because of personal preference and because I've never had a problem with Ford Racing when I've purchased a defective part, but if you're looking for the "cheaper" part the Thumprs are $80 less. That wasn't enough to sway me away from the Hot Rods, but if that's a factor then I see no problem going with them. Good luck with your decision! Quote Link to comment Share on other sites More sharing options...
07SGT Posted February 21, 2012 Report Share Posted February 21, 2012 Someone else on this site, possibly Kurgan, installed I believe Thumper cams and had an issue with the valve train. I believe a part of the valve train broke and led to a major problem. Hopefully he will chime in. Quote Link to comment Share on other sites More sharing options...
JeffJ Posted February 21, 2012 Report Share Posted February 21, 2012 I have the Hot Rod cams. Love the sound. Now when I first put them in, I actually lost quite a bit of time in the quarter mile, but gained a ton of top end speed. So on an automatic car, it takes a bit too much bottom end torque for me. Gained really nice on the top, but lost quite a bit on the bottom. With a 5 speed car, it wouldn't be nearly as noticable. They are probably hurting me more now that I'm supercharged, but hoping with the new gears, throttle body, converter, 2.6 pulley, and a few other things that a good local tune will get the most out of them as possible. Heck, I'd happily give up some bottom end to keep the sound of the cams. They are awesome! Hopefully with the new changes, I should have plenty of bottom end now. I've heard a couple cars with the mutha thumpers also and they sound amazing. One reason I stayed with the Hot Rods is the fact of not needing to change springs, or the cam phazer limiters. It really depends on what you are looking to get out of them. Quote Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted February 21, 2012 Report Share Posted February 21, 2012 I also went with the Hot Rod cams, like jeff said they are designed to work with the stock springs and cam phazers. I also agree with JT93 and felt better putting something made by ford racing in my engine then someone else's parts. As far as losing bottom end, If your running 4:10's now then you won'tt even notice it. I noticed a slight drop in the bottom end with the 3:55's but like you I'm upgradeing to 4:10's over the summer. Jeff Quote Link to comment Share on other sites More sharing options...
SGT0128 Posted February 21, 2012 Author Report Share Posted February 21, 2012 I also went with the Hot Rod cams, like jeff said they are designed to work with the stock springs and cam phazers. I also agree with JT93 and felt better putting something made by ford racing in my engine then someone else's parts. As far as losing bottom end, If your running 4:10's now then you won'tt even notice it. I noticed a slight drop in the bottom end with the 3:55's but like you I'm upgradeing to 4:10's over the summer. Jeff Was their a specfic part number you used? Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted February 21, 2012 Report Share Posted February 21, 2012 M-6550-3V Late Model Restoration $730 with free shipping I am running these with 4.10's and love them, also have American Racing Long Tubes Andrew Quote Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted February 21, 2012 Report Share Posted February 21, 2012 I got mine from American Muscle over the summer with the new cam phaser bolts and did the install with a friend. It looks like AM's price went up on the cams though cause I didn't pay that much. I don't remember the exact price then since I got the Ford racing valvle covers at the same time. I figured theere going to be off anyway might as well swap em now. It think it all came to $1000 for cams, phaser bolts and the new valve covers. Like Andrew posted above looks like Late model might have the best deal right now. Keep us posted on what you decide. Either way I'm sure you'll love the sound and the rocking of the car. Jeff Quote Link to comment Share on other sites More sharing options...
springer Posted February 21, 2012 Report Share Posted February 21, 2012 (edited) I have the Hot Rod cams and didn't notice any power loss with the Whipple. Edited February 21, 2012 by springer Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted February 21, 2012 Report Share Posted February 21, 2012 I play a CD of the hot rod cams cheaper that way !!!! Quote Link to comment Share on other sites More sharing options...
ARMORINE Posted February 21, 2012 Report Share Posted February 21, 2012 personaly i feel the mutha thumprs are a more powerful cam. i have them and love them to death but they arnt without there downside. they dont create much vacuum so powering the brakes at idle is a problem. i have a aux vacuum tank on mine and it helps alot. since i road race mine i do need more vacuum though. im going to be installing a vacuum pump in a few weeks after i get my car running again. honesty though the way they sound is just amazing. Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted February 22, 2012 Report Share Posted February 22, 2012 personaly i feel the mutha thumprs are a more powerful cam. i have them and love them to death but they arnt without there downside. they dont create much vacuum so powering the brakes at idle is a problem. i have a aux vacuum tank on mine and it helps alot. since i road race mine i do need more vacuum though. im going to be installing a vacuum pump in a few weeks after i get my car running again. honesty though the way they sound is just amazing. Hotrod cams sound like a hotrod of the old days !!! Quote Link to comment Share on other sites More sharing options...
