Ford Fest Posted February 19, 2012 Report Share Posted February 19, 2012 We've all seen Grabber's thread on the proper way to jack or lift a GT500 and as with all of Rob's threads, very well done. I don't think this will work on a 40th due to the carbon fiber rocker panels or the rear brake cooling ducts. I would like to lift the car enough to be able to pull off the tires so I can clean the inner and outer of the wheels along with the inner fenders. Any ideas? Quote Link to comment Share on other sites More sharing options...
Slabo Posted February 19, 2012 Report Share Posted February 19, 2012 Bob I do this all the time using the designated pinch weld jack points under the rockers. I use both a scissor type jack or a small hydraulic jack. You do have to be careful how to place the jack so you don't damage the rockers. I use a small rectangular piece of 3/4" plywood between the jack and the pinch weld as a spacer so the jack does not contact the rocker panel. Quote Link to comment Share on other sites More sharing options...
MY500SS Posted February 19, 2012 Report Share Posted February 19, 2012 Bob I do this all the time using the designated pinch weld jack points under the rockers. I use both a scissor type jack or a small hydraulic jack. You do have to be careful how to place the jack so you don't damage the rockers. I use a small rectangular piece of 3/4" plywood between the jack and the pinch weld as a spacer so the jack does not contact the rocker panel. Same here. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 19, 2012 Author Report Share Posted February 19, 2012 Bob I do this all the time using the designated pinch weld jack points under the rockers. I use both a scissor type jack or a small hydraulic jack. You do have to be careful how to place the jack so you don't damage the rockers. I use a small rectangular piece of 3/4" plywood between the jack and the pinch weld as a spacer so the jack does not contact the rocker panel. Are you using a scissor jack with a small dent or one that is flush on top? If possible could you take a pic next time? I think I could on the front with a cut out, but can't figure out the back. I'm not following you on the 3/4" plywood. Sorry. Quote Link to comment Share on other sites More sharing options...
08KR525 Posted February 19, 2012 Report Share Posted February 19, 2012 (edited) I would like to see a picture of this too, as the pinch weld looks to be flush with then rocker. I don't see how to lift it without contacting the rocker trim. Edited February 19, 2012 by 08KR525 Quote Link to comment Share on other sites More sharing options...
Slabo Posted February 21, 2012 Report Share Posted February 21, 2012 Yeah a pic would make it easier to explain. I will see if I can get out to the shop tomorrow and take a photo. Quote Link to comment Share on other sites More sharing options...
Slabo Posted February 24, 2012 Report Share Posted February 24, 2012 Here is a photo of how I jack up the car. I did notice that my CF rockers are not really in the way of the jack point with anything that is flat. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 24, 2012 Author Report Share Posted February 24, 2012 Thanks for posting the pic. I'll give it a try this weekend. Quote Link to comment Share on other sites More sharing options...
Torch40 Posted February 24, 2012 Report Share Posted February 24, 2012 Get yourself a floorjack from Harbor Freight. $90. Makes it so much easier and safer than scissor jacks. While your at it get a couple short jack stands http://www.harborfreight.com/rapid-pump-15-ton-compact-aluminum-racing-jack-68053-html-7814.html Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 25, 2012 Author Report Share Posted February 25, 2012 Here is a photo of how I jack up the car. I did notice that my CF rockers are not really in the way of the jack point with anything that is flat. Assuming this is a photo from the rear. I don't see the brake cooling ducts. I think that is what is causing most of my issues, when trying to find a good lifting point. Trying to get around the rockers and the ducts, kinda sucks. But they look pretty cool. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 25, 2012 Author Report Share Posted February 25, 2012 Get yourself a floorjack from Harbor Freight. $90. Makes it so much easier and safer than scissor jacks. While your at it get a couple short jack stands http://www.harborfre...-html-7814.html Great find! I have a floor jack, but it was too tall to get under the rockers. I'll visit the local Harbor Freight. Quote Link to comment Share on other sites More sharing options...
07REDGT500 Posted February 25, 2012 Report Share Posted February 25, 2012 This is what I made to lift mine. Works great. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 25, 2012 Author Report Share Posted February 25, 2012 This is what I made to lift mine. Works great. Okay, more details. How did you make it? What is the orange piece and how do I get one? How does it work lifting the rear trying to navigate around the rocker and brake cooling ducts? Quote Link to comment Share on other sites More sharing options...
07REDGT500 Posted February 26, 2012 Report Share Posted February 26, 2012 It is made from aluminum bar stock and powder coated. Not sure about the brake ducts. I will take a look tomorrow. I took my rear ducts off because I run the stock wheels when I go to the track and they don't fit with the stock wheels. If you what one I am sure we could work something out. Quote Link to comment Share on other sites More sharing options...
Robert OHara Posted February 26, 2012 Report Share Posted February 26, 2012 It is made from aluminum bar stock and powder coated. Not sure about the brake ducts. I will take a look tomorrow. I took my rear ducts off because I run the stock wheels when I go to the track and they don't fit with the stock wheels. If you what one I am sure we could work something out. I think I could use one. Quote Link to comment Share on other sites More sharing options...
Slabo Posted February 26, 2012 Report Share Posted February 26, 2012 (edited) That is nice Bob I could use one or two as well. Edited February 26, 2012 by Slabo Quote Link to comment Share on other sites More sharing options...
cobrafan Posted February 26, 2012 Report Share Posted February 26, 2012 A pretty neat gizzmo. You might want to take orders and sell these suckers. Good job! Quote Link to comment Share on other sites More sharing options...
07REDGT500 Posted February 26, 2012 Report Share Posted February 26, 2012 Looks like I should bring some to the Bash. If I make some I could probably do them for $25.00. Quote Link to comment Share on other sites More sharing options...
Venom4U Posted February 27, 2012 Report Share Posted February 27, 2012 I would be a player also. Quote Link to comment Share on other sites More sharing options...
cobrafan Posted February 27, 2012 Report Share Posted February 27, 2012 I'm in for $25 bucks! Quote Link to comment Share on other sites More sharing options...
FormerGmc Posted February 27, 2012 Report Share Posted February 27, 2012 I'm in for $25 bucks! Me Too! Quote Link to comment Share on other sites More sharing options...
Slabo Posted February 27, 2012 Report Share Posted February 27, 2012 Cool Bob, put me down for one at $25 as well. Quote Link to comment Share on other sites More sharing options...
stronger66 Posted February 27, 2012 Report Share Posted February 27, 2012 is it to late to get an order in for one of those custom jobs to must be nice have the equipment to mil one of those out! Mike Quote Link to comment Share on other sites More sharing options...
jnf Posted February 27, 2012 Report Share Posted February 27, 2012 I would be in for 1 or even 2 of those. Great idea. Quote Link to comment Share on other sites More sharing options...
Robert OHara Posted February 27, 2012 Report Share Posted February 27, 2012 Will not be at the bash , but do want one Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted February 28, 2012 Author Report Share Posted February 28, 2012 It is made from aluminum bar stock and powder coated. Not sure about the brake ducts. I will take a look tomorrow. I took my rear ducts off because I run the stock wheels when I go to the track and they don't fit with the stock wheels. If you what one I am sure we could work something out. Glad you're driving to the Bash, otherwise you may need to check an additional bag on the plane with all of the "insert a name for your invention" everyone is asking for. Since I started this please put me down for one. I won't be making it to the Bash so I'll need to give you extra for shipping. Quote Link to comment Share on other sites More sharing options...
Jer Posted February 28, 2012 Report Share Posted February 28, 2012 (edited) Looks like I should bring some to the Bash. If I make some I could probably do them for $25.00. Count ME in for one of those... As for a name, my first impression was "JackPuck". LOL... Jer Edited February 28, 2012 by Jer Quote Link to comment Share on other sites More sharing options...
07REDGT500 Posted February 28, 2012 Report Share Posted February 28, 2012 I guess I need to order up a length of bar stock. Quote Link to comment Share on other sites More sharing options...
rpbt Posted February 28, 2012 Report Share Posted February 28, 2012 I would be in for 2. Not going to the bash but will pay for shipping Quote Link to comment Share on other sites More sharing options...
ati Posted February 28, 2012 Report Share Posted February 28, 2012 Please put me down for one, I'm not going to the bash and will gladly pay shipping. Quote Link to comment Share on other sites More sharing options...
