rice eater Posted February 19, 2012 Report Share Posted February 19, 2012 Ok guys need your help me and my buddy got a bet going on his modded 2011 Z06 i think he has a tune cold air kit and headers vs my 2009 super snake 3.6 kenne bell with coolant upgrade in the quartermile. I have about 4500 dollars to spent on some mods what are going to yield me the best quartermile times. My buddy said he is doing a couple other mods to his Z06 don't know what he is doing yet. Help this super snake beat this Z06 thanks. Link to comment Share on other sites More sharing options...
Robert M Posted February 19, 2012 Report Share Posted February 19, 2012 Ok guys need your help me and my buddy got a bet going on his modded 2011 Z06 i think he has a tune cold air kit and headers vs my 2009 super snake 3.6 kenne bell with coolant upgrade in the quartermile. I have about 4500 dollars to spent on some mods what are going to yield me the best quartermile times. My buddy said he is doing a couple other mods to his Z06 don't know what he is doing yet. Help this super snake beat this Z06 thanks. Traction aids to start with............ R Link to comment Share on other sites More sharing options...
BoneDoc Posted February 19, 2012 Report Share Posted February 19, 2012 traction and practice launching. if you can launch with him, your HP should pull him. LCA relocation bracket and drag radials would be a good start. good luck Link to comment Share on other sites More sharing options...
MY500SS Posted February 19, 2012 Report Share Posted February 19, 2012 I agree with my SS brothers..............traction, traction and more traction. Good luck. Link to comment Share on other sites More sharing options...
rice eater Posted February 19, 2012 Author Report Share Posted February 19, 2012 traction and practice launching. if you can launch with him, your HP should pull him. LCA relocation bracket and drag radials would be a good start. good luck Would drag radials be better than widened my rears also were did you purchase your relocation bracket and how much. Link to comment Share on other sites More sharing options...
BoneDoc Posted February 19, 2012 Report Share Posted February 19, 2012 I went with CHE relocation brackets. they are easy to install, beefy, and adjustable. http://www.cheperformance.com/CartGenie/prod-264.htm. about 60 bucks. When i go to the drag strip i pull out the old stock GT500 rims (18") and use Nitto 305/45/18's. they are not as wide as my SS wheels (335's) but i think having the extra side wall (deflating the tire to 16PSI) and softer compound helps with bite. hope that helps. if you have a few extra bucks get a linelock installed so you can heat'em up before your run. get some video! Ron Link to comment Share on other sites More sharing options...
Robert M Posted February 20, 2012 Report Share Posted February 20, 2012 Here is what was achieved with a 725 on 18" M/T E.T. Streets........... Sitting in the drivers seat the first thoughts are "rev it up and launch it", but as the article reports, a lower RPM netted the better time, and that was a very low RPM launch. You are going to have to find what works best for you once the traction aids are in place. From what I read, that ZR-1 is also in the 10.80's stock, with the right driver. R Link to comment Share on other sites More sharing options...
dbackg Posted February 20, 2012 Report Share Posted February 20, 2012 All very good advice. Improve the rear end suspension: See post 13 http://www.teamshelb...44#entry1136944 Improve your traction: See below. http://www.teamshelb...ger-rear-tires/ http://www.teamshelb...eels-and-tires/ http://www.vmptuning...hread.php?t=938 Then practice your launches. Link to comment Share on other sites More sharing options...
