TSB 11-10-18 RECARO SEATS—TRIM BEZEL LOOSE
Grabber
FORD: 2012 Mustang
ISSUE:
Some 2012 Mustang Boss and GT500 vehicles equipped with Recaro front seats and built on or before 5/9/2011 may exhibit a concern with the driver and/or passenger side seat trim bezel warping or coming loose.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the seat trim bezels in both the drivers and passenger seat with the new design bezels in the service kit. Follow the installation instructions included with the kit. Two (2) kits are required. Each kit services one seat.
PART NUMBER PART NAME CR3Z-6360220-CA Bezel Kit (2 Req)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. OPERATION DESCRIPTION TIME 111018A 2012 Mustang With Recaro Seats: Replace The Shoulder Strap Pass Through Covers On Both Front Seats (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE 6360220 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2011 Ford Motor Company
TSB 11-10-18 2012 Recaro Seats-Trim Besel loose.pdf
  • 1 month later...
  • 2 weeks later...
  • 2 months later...
Update from earlier post - Ford ordered the replacement bezels and put them on within a week. It helped that I emailed my service advisor the TSB from above and pics of my warped seat bezels. It also saved me a trip to the dealer just to have them "check it out" in order to place an order. Thanks for posting the TSB! What an amazing difference the new bezels make on the Recaro seats. YEAH!
Charlotte 10
