Torched10 Posted February 3, 2012 Report Share Posted February 3, 2012 thought i posted this earlier but don t see it.After several years of working great whenever i start the car and push the radio button, my zune is not playing tru the USB port.Checked volumes on both, restarted the zune. conected the zune to my PC and it works fine0--cant find my SYNC manual sodont know what else to try--any thoughts bob Link to comment Share on other sites More sharing options...
Boidster Posted February 3, 2012 Report Share Posted February 3, 2012 I can e-mail you the PDF of the SYNC user guide (for a 2012), if that would help. I don't have a Zune and I do have the Nav package, so I'm not sure I'd be able to help directly. I use the Slacker SYNC app on an iPhone, so totally different application. This thread over at Microsoft seems to say that formatting the Zune (and reloading your music, I suppose) fixed a similar problem. Good luck. Link to comment Share on other sites More sharing options...
Torched10 Posted February 4, 2012 Author Report Share Posted February 4, 2012 thanks i PMed my email address Link to comment Share on other sites More sharing options...
Torched10 Posted February 4, 2012 Author Report Share Posted February 4, 2012 ok being an engineer i tried to eliminate things---the zune works in my STS V using wh-red-yellow cables--so im guessing the unit works.Then tried a single cable from te zune into the sync--again the Zune plays,altough not able to use voice commands--so again Zune works. Coonected the Zune to my PC using the USB cable abd the PC sees the Zune unit, so im thinking the cable is ok, although itis possible the pin needed to play music thru SYNC may be bad. So its either a bad cable, which i doubt, or the uSB connection in the Shelby may be bad--Ill try and fine anotehr cable, if not ill bring it to the dealer--- Link to comment Share on other sites More sharing options...
DaFreak Posted February 5, 2012 Report Share Posted February 5, 2012 Torched10, why the name change? Just wondering. Link to comment Share on other sites More sharing options...
Torched10 Posted February 5, 2012 Author Report Share Posted February 5, 2012 dafreak---that was my pontiac name, my GTO is a pretty rare 4 spd tri-power vert,all original--when i got the shelby 3 years ago, thought it was time to adopt-- On the zune, it turned out to be a cable--tried another and it worked--thansk everyone Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted February 7, 2012 Report Share Posted February 7, 2012 I had the same issue with my Zune HD so i wiped it clean and reloaded everything and it worked fine after that. Yeah it seems like too much trouble just to get the Zune to work, but it fixed my issue. Link to comment Share on other sites More sharing options...
Torched10 Posted February 8, 2012 Author Report Share Posted February 8, 2012 for future refernce how do you wipe a zunes memory clean-i only have a 1000 songs on mine,and they are all on my PC,but id imagine itd be a bit of a pain to add the songs again Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted February 8, 2012 Report Share Posted February 8, 2012 for future refernce how do you wipe a zunes memory clean-i only have a 1000 songs on mine,and they are all on my PC,but id imagine itd be a bit of a pain to add the songs again Plug your Zune into your computer then start the Zune application. In the top right hand corner of the Zune application, click Settings. Once in settings, select the tab that supports your device. In the column, you should already be on Sync Options. Within the information on the right you will see Erase All Content. This will clear your Zune and you can then start over fresh. Link to comment Share on other sites More sharing options...
96slowbra Posted February 14, 2012 Report Share Posted February 14, 2012 sometimes you need to disconnect the battery of the car for over 10 minutes, this is to reset sync. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted February 15, 2012 Report Share Posted February 15, 2012 The update will be out in a few weeks...might want to just hang in there. Link to comment Share on other sites More sharing options...
