what size tires for supersnake rims?
GT500racing01
the actual Super Snakes come with 255/35-20 up front and 275/35-20 in the back. Im running the same suspension and have 275/35-20 Nitto Invos mounted on the 20x9 rims up front with no problem. I'm running a 315/30-20 in the back but had my rims widened for that. I think most with these rims just run either the normal Super Snake sizes or swap a 285/30-20 in the back
I'm currently running 275/35-20 up front and 295/30-20 out back without issues. I have an '08 with the FRPP suspension. I don't like the short sidewall on the 295's, so I think the next time I'll do a 295/35. I went with the 295/30 since it doesn't change the speedo. Going up to the 35 series will require a "wheel adjustment" (RPM) with the SCT (or other tool).
How much did you widen the rear rims and what off set ???
How do you like the 315's? Do they affect your high speed cornering? I am running 305's that they recommended, but was going to get a seperate set of wheels to run 315's at the drag strip.
