crayonbreaking83 Posted April 5, 2007 Report Share Posted April 5, 2007 On the dash in the Instrument cluster, the airbag sensor malfunction light has been flickering on and off and random intervals and then on solid. is this common?? __________________ I noticed that the manual says it's a sensor malfunction light... Here is the picture of which light... But now... Interestingly enough...today the light hasn't come on at all. Link to comment Share on other sites More sharing options...
Son of GT Posted April 5, 2007 Report Share Posted April 5, 2007 I understand that light will come on anytime there is a bigger Airbag in the car. You didn't happen to have your Mother-In-Law catch a ride with you did you? Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted April 5, 2007 Report Share Posted April 5, 2007 when I sent my air-bag cover to SAI (which I'm still waiting for it to come back) I disconnected the Air Bag & took it out. when I move my car around (in/out) of the garage the light flashes & then goes solid. I say check the connection (after disconnecting the battery) to make sure it's plugged in all the way & then hook the battery back up & see if the problem goes away. If not take it to the dealer & have them check it out. hope this helps. CWHR Link to comment Share on other sites More sharing options...
yamahar1 Posted April 7, 2007 Report Share Posted April 7, 2007 I understand that light will come on anytime there is a bigger Airbag in the car. You didn't happen to have your Mother-In-Law catch a ride with you did you? Could it be the blow up doll bouncing around in the seat? Just a thought? Link to comment Share on other sites More sharing options...
