Engine Security Wire
I am trying to find a replacement for the thin wire seal that is attached to the engine on mt GT-H.
Does anyone know where I might get one, or how to make one? It doesn't seem to be available on the Shelby Parts section of the site.
Thanks.
Problem is finding the security wire. Plenty of companies make security wire, but finding a small quantity may be a trick. This is the type of wire that was used. This company also sells the seals like you would need. May contact them and see if they can get you a small example quantity to help you out.
http://americancasting.com/info-wire-seals-wire.asp
  • 1 month later...
Just a suggestion, every GT-H owner who has obtained the Hertz install records may want to look at the mult-point install checklist. You may find that the "wire" was checked as "missing". Car # 06-0007 came without the wire and was so noted on the checklist (later installed). The wire was intended to be on the cars but frequently was found to be missing upon the car's arrival at a Hertz location. While the installed wire may have been the norm, it WAS frequently omitted, so with or without the wire may be correct depending on your specific car. Just a thought, regards, Larry
