MMS Muffler Install ?
Same question Randy had earlier on installing Alex's MMS mufflers on SGT
The FRPP GTA muffler has a notch in it that fits over a button the exhaust pipe
But the MMS has no notch
Per Alex the GT500 exhaust does not have the notch, which is why the MMS is notchless
So, should I cut a notch or not?
Dang too many "n's"
If yes, guess a die grinder then finish up with dremel tool
Any other suggestions?
Thanks
Larry
Picture of the FRPP
Picture of the exhaust pipe with the button & MMS slid on
Update:
I finished the MMS mufflers install this morning
The notch & button on the exhaust pipe turned out to be a non-issue
The flange on the FRPP GTA's is slightly longer than on the MMS mufflers, so it goes past the little button thing on the exhaust pipe
Whereas the fitment on the MMS ends exactly flush with the button, so no need to notch the pipe
On another install note, the clamps that come with the MMS match up perfect with the slots in the flange
I was going to use the FRPP clamps given they are wider, but they are wider than the slots in the flange so it didn't seem to be a good match up
After finishing the install I grabbed my keys & wallet but the wonderful Pacific NW rain beat me to a test drive
Usually I don't mind driving the SGT occasionally in the rain, which is definitely a reality in the NW
But the temp is too close to freezing and the Goodyear F1 tires definitely do not like to get their feet cold
Lg
