SNKDOUT Posted November 27, 2011 Report Share Posted November 27, 2011 I have the 3.6L Kenny Bell Super Charger. When I am running in 5th or 6th gear, I hit the peddle with over 7 PSI boost, and the engine revs and then takes off, Not sure if I am just spinning the tires of if there is something wrong? Any insite would be appreciated! Quote Link to comment Share on other sites More sharing options...
Revan Racing Posted November 27, 2011 Report Share Posted November 27, 2011 I have the 3.6L Kenny Bell Super Charger. When I am running in 5th or 6th gear, I hit the peddle with over 7 PSI boost, and the engine revs and then takes off, Not sure if I am just spinning the tires of if there is something wrong? Any insite would be appreciated! Sounds like a possible slipping clutch. Give me a call if you would like to discuss. Van Revan Racing 561-445-7702 Quote Link to comment Share on other sites More sharing options...
SNKDOUT Posted November 27, 2011 Author Report Share Posted November 27, 2011 I will give you a call tomorrow if that's ok. What time zone are you? Quote Link to comment Share on other sites More sharing options...
Revan Racing Posted November 27, 2011 Report Share Posted November 27, 2011 I will give you a call tomorrow if that's ok. What time zone are you? I'm in Florida. EST. I enjoyed speaking with you this afternoon and I look forward to working with you in the future. Van Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 29, 2011 Report Share Posted November 29, 2011 I have the 3.6L Kenny Bell Super Charger. When I am running in 5th or 6th gear, I hit the peddle with over 7 PSI boost, and the engine revs and then takes off, Not sure if I am just spinning the tires of if there is something wrong? Any insite would be appreciated! Yeah, I totally agree with Van. That is a classic symptom of a slipping clutch. You are about to buy a new clutch friction disc & pressure plate, and if you go too far, possibly a flywheel or a flywheel resurface/grind. Phill Quote Link to comment Share on other sites More sharing options...
