gearhed31 Posted November 14, 2011 Report Share Posted November 14, 2011 (edited) I'm looking at a few different KR's that are currently for sale. Ran across something interesting on one of the window stickers. In the lower left corner there is a box with a date that is usually within a week of the build date. However, on this particular sticker, the date is listed as 06 17 2011 ?? Anybody have any insight ?? I've attached the window sticker as well as another example in the next post that shows what I think is normal. Thanks, Scott 2008 GT500KR - RD.pdf 2008 GT500KR - RD.pdf Edited November 14, 2011 by gearhed31 Quote Link to comment Share on other sites More sharing options...
gearhed31 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Another sticker that seems to have the more "correct" date: GT500KR Indy.pdf GT500KR Indy.pdf Quote Link to comment Share on other sites More sharing options...
txcobra Posted November 14, 2011 Report Share Posted November 14, 2011 Believe that's relative to the print date of the sticker, so probably just means its a reprint of that sticker. Not positive on this, but I think that's the case. Quote Link to comment Share on other sites More sharing options...
eagledriver Posted November 14, 2011 Report Share Posted November 14, 2011 Believe that's relative to the print date of the sticker, so probably just means its a reprint of that sticker. Not positive on this, but I think that's the case. Yep, that is exactly the cause of the later date. Probably the sticker ripped while putting window up/down or they took it off for one reason or another. I'd verify the mileage but if new and under 25 miles than no cause for alarm. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 16, 2011 Report Share Posted November 16, 2011 Another sticker that seems to have the more "correct" date: When I opened this one up, it shows a date of 11/09/11. How is that "more correct:"? It should show a date in '07, '08 or '09, no? They certainly didn't make any KR's in 2011. Phill Quote Link to comment Share on other sites More sharing options...
shelbymotorsports Posted November 16, 2011 Report Share Posted November 16, 2011 Those are not "real" Monroney labels but PDF's from Fords website. The date shown will be the date someone produced a PDF label on Ford's website. For example if I were to take that KR VIN number this morning and run it thru Ford's website the label would be dated with todays date of 11/16/2011. Steve Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 16, 2011 Report Share Posted November 16, 2011 For example if I were to take that KR VIN number this morning and run it thru Ford's website the label would be dated with todays date of 11/16/2011. Steve I thought that might be the case. I pulled mine up the other day for a example in another thread but I didn't pay attention to the date on the bottom. Ya learn somethin' new every day. Thanks Steve, Phill Quote Link to comment Share on other sites More sharing options...
gearhed31 Posted November 16, 2011 Author Report Share Posted November 16, 2011 (edited) Those are not "real" Monroney labels but PDF's from Fords website. The date shown will be the date someone produced a PDF label on Ford's website. For example if I were to take that KR VIN number this morning and run it thru Ford's website the label would be dated with todays date of 11/16/2011. Steve Not sure if I completely agree with that, I just pulled up my Boss window sticker today and it has a date of 06/02/2011. See the KR window sticker attached, look at the field highlighted in red. It's not the date all the way at the bottom, that's the date that it was generated from the Ford window sticker site (11/13/2011). Just was a mystery to me why that particular KR has a 06/17/2011 date. It's to the right of the Final Assembly Point box. 2008 GT500KR - RD1.pdf 2008 GT500KR - RD1.pdf Edited November 16, 2011 by gearhed31 Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 16, 2011 Report Share Posted November 16, 2011 (edited) See the KR window sticker attached, look at the field highlighted in red. It's not the date all the way at the bottom, that's the date that it was generated from the Ford window sticker site (11/13/2011). Huh. I never knew that date was there. On my car (2010) the production date is up in the top left corner, just to the right of the "FLR" number. I noticed that all 3 of the examples shown don't have that up there. I'll pull up mine and see if the lower production date is there or not. EDIT: Here is my window sticker. The date you had highlighted in red is there but it is *not* the same date as the production date noted in the code at the top of the sticker. My car has a August or September production date (I can't remember which and don't have time to get into my records) and the date listed at the bottom is a July date. BUT, I believe my car was ORDERED in July so that's likely the date the order was placed. Still, that doesn't address the KR with a 2011 order/production date on it! How strange..... Thanks for pointing that (date) out, Phill Edited November 16, 2011 by 2010KonaBlueGT Quote Link to comment Share on other sites More sharing options...
shelbymotorsports Posted November 16, 2011 Report Share Posted November 16, 2011 Not sure if I completely agree with that, I just pulled up my Boss window sticker today and it has a date of 06/02/2011. See the KR window sticker attached, look at the field highlighted in red. It's not the date all the way at the bottom, that's the date that it was generated from the Ford window sticker site (11/13/2011). Just was a mystery to me why that particular KR has a 06/17/2011 date. It's to the right of the Final Assembly Point box. It appears I misunderstood the OP's question. I thought he was referring to the date at the bottom of the PDF. Let me look into this other date. Steve Quote Link to comment Share on other sites More sharing options...
shelbymotorsports Posted November 16, 2011 Report Share Posted November 16, 2011 I've found another 2008 KR showing a 2011 date. I've also run several 2008 KR's that show a correct date and noticed something. On the KR's with the 2011 date the PDF is missing information at the top which normally includes another date. See pic below. Perhaps these incorrectly dated ones were caused by a dealership ordering a replacement label for a damged or lost label? Steve Quote Link to comment Share on other sites More sharing options...
gearhed31 Posted November 17, 2011 Author Report Share Posted November 17, 2011 (edited) I've found another 2008 KR showing a 2011 date. I've also run several 2008 KR's that show a correct date and noticed something. On the KR's with the 2011 date the PDF is missing information at the top which normally includes another date. See pic below. Perhaps these incorrectly dated ones were caused by a dealership ordering a replacement label for a damged or lost label? Steve Steve- That would make sense. The sticker that I initially posted with the strange date 6-17-11, I believe the car was sold new off the showroom floor around that time frame. Thanks, Scott Edited November 17, 2011 by gearhed31 Quote Link to comment Share on other sites More sharing options...
Mustangcollector Posted September 3, 2012 Report Share Posted September 3, 2012 Recycling this message for no other reason than I was surfing the forum and out of curiosity I tested the VIN website to see if it matched my Monroney sticker. I ran the VIN for my 2008 KR through the website and out came my exact window sticker, BUT contrary to what some of you folks are finding the sticker from the website DOES have the original build date (as opposed to today's date) which matches my actual sticker: it is "04 11 2008". So, not sure why you've found stickers that have a date after 2009. Quote Link to comment Share on other sites More sharing options...
S8MS-01904 Posted September 4, 2012 Report Share Posted September 4, 2012 (edited) double post, nothing to see here - move along..... Edited September 4, 2012 by S8MS-01904 Quote Link to comment Share on other sites More sharing options...
S8MS-01904 Posted September 4, 2012 Report Share Posted September 4, 2012 Those dates you are referring to are the "in service" date of the KR as a sold unit. This is when the warranty begins. Check the Oasis Report to confirm. This would give the edge to the KR with factory bumper to bumper warranty vs. no warranty when shopping for a KR. Quote Link to comment Share on other sites More sharing options...
The Chairman Posted September 10, 2012 Report Share Posted September 10, 2012 (edited) To add to the info base, I have three versions of my window sticker for a 2009 GT500KR, all with different dates: 1. Original Sticker (appears to be the build date: Sep 23, 2008) 2. Printed from dealer inventory just before I bought the car. Has two dates, the lower date is when I downloaded and printed (May 19, 2010). The other date doesn't correlate to anything (June 15, 2009) 3. New one from Ford purchased for display purposes. The date is when they printed it (Aug 2, 2011) None of these dates are related to warranty start or in-service date, etc. Interesting.... See attached. Update: Had an Oasis report pulled and found the build date was Oct 6, 2008. This does not match the Sep 23, 2008 date on the original sticker. Also, the warranty start date does not match any of the dates above. My conclusion so far is that the date noted on the sticker is when it was printed (presuming my sticker was printed a few days before the car was built and was waiting at the end of the assembly line to be installed....) Edited September 10, 2012 by dhoening Quote Link to comment Share on other sites More sharing options...
The Chairman Posted September 10, 2012 Report Share Posted September 10, 2012 And here's the third sticker w/date Quote Link to comment Share on other sites More sharing options...
S8MS-01904 Posted September 10, 2012 Report Share Posted September 10, 2012 OK, now I'm cornfused. I was led to believe the dates in question were in service dates, now I'm not sure. I guess I'd still like to "see" what the Oasis Report shows. Anybody else have some insight???? Quote Link to comment Share on other sites More sharing options...
