cobra2564 Posted October 31, 2011 Report Share Posted October 31, 2011 OK, people. I think we've been here before so sorry in advance. I need to order an oil filter for my 2010 GT500. I have the old box flap and I have a part number of CM-6731-FL820. I see Shelby has M-6731-FL820. What is, if any the difference? Just a part number change? I want to use the racing one as it has more pleats of filtration. Thanks. Quote Link to comment Share on other sites More sharing options...
bigsnake Posted October 31, 2011 Report Share Posted October 31, 2011 OK, people. I think we've been here before so sorry in advance. I need to order an oil filter for my 2010 GT500. I have the old box flap and I have a part number of CM-6731-FL820. I see Shelby has M-6731-FL820. What is, if any the difference? Just a part number change? I want to use the racing one as it has more pleats of filtration. Thanks. Don't believe there is any difference in the two you posted. Here's a comparison of the 6731- FL820 racing filter and standard FL820S and notice the differences. Ford Racing CM-6731-FL820 Oil Filter Measurements * Filter Weight - 19.75 oz * Can OD - 3.68" / Seam OD - 3.76" * Overall Height - 3.99" * Can Material - 0.019" thick steel * Filter Element OD - 3.44" (at element) * Filter Element Height - 2.81" * Media - Cellulose - Synthetic Mix? Oiled? (appears orange) * Number of pleats - 63 + 1 joint * Depth of pleats - 0.73" * Media length (unrolled) - 100" (seam crimped) * Media width (glue not included) - 2.50" * Media thickness - 0.029" * Total media surface area - 250 sq. in. * Total media volume - 7.25 cu. in. * Inner Filter Support Material - 0.010" Thick Perforated Steel * Inner Filter Support OD - 1.71" * Indentifying marks Can - 810050516 / Made in USA Bar Code - 7_56122_07567_8 Label - 6945234 Base - 22 / MM * Gasket Retention - Multiple Crimps * Thread - M22-1.5 * Relief Valve Location - base end * ADBV Material - Silicon Motorcraft FL-820S Measurements * Filter Weight - 13.1 oz * Overall OD - 3.76" @ seam / 3.66 @ can * Overall Height - 4.05" * Can Material - 0.02" thick steel * Filter Element OD - 3.25" * Filter Element Height - 2.51" * Media - Cellulose (appears pink/orange) * Number of pleats - 43 + 1 joint * Depth of pleats - 0.68" * Media length (unrolled) - 65.5" * Media width (glue not included) - 2.375" * Media thickness - 0.035" * Total media surface area - 156 sq. in. * Total media volume - 5.4 cu. in. * Inner Filter Support Material - 0.012" Thick Perforated Steel * Inner Filter Support OD - 1.68" * Indentifying marks Can - Made in USA ADBV - 6944453 / AAX / 150 * Gasket Retention - Multiple Crimps * Thread - M22-1.5 * Relief Valve Location - base end * ADBV Material - Silicone (orange) Quote Link to comment Share on other sites More sharing options...
07SGT0547 Posted October 31, 2011 Report Share Posted October 31, 2011 (edited) I just looked at those two same numbers yesterday on the FRPP site... One is for the individual filter and the other is for the Case of 12... By the CASE... Individually... Otherwise, same - same Edited October 31, 2011 by 07SGT0547 Quote Link to comment Share on other sites More sharing options...
Madlock Posted October 31, 2011 Report Share Posted October 31, 2011 Just buy the case (if it's within your budget) - and save yourself a headache. Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted November 1, 2011 Author Report Share Posted November 1, 2011 Just buy the case (if it's within your budget) - and save yourself a headache. Thanks for all the input! You all have been a great help! Quote Link to comment Share on other sites More sharing options...
