steve-s Posted October 31, 2011 Report Share Posted October 31, 2011 I have a 07 GT500 and today installed a K&N CAI kit that was supposed to be a plug and play according to K&N. Took it out for a test run and it threw a check engine light. I plan on taking it off tomorrow and am slightly pissed. ANYONE know if there is a way to reset the check engine light "without" a scan tool?? Appreciate any help that might save me some dough. Steve Arizona Quote Link to comment Share on other sites More sharing options...
Grabber Posted October 31, 2011 Report Share Posted October 31, 2011 Steve, you can reset the dummy light by disconnecting the battery for 5 minutes and then reconnecting it. This will clear the code. If the code comes back...you have a problem that needs to be looked at. BTW get rid of the K and N product. In my opinion you should go with VMP or JLT or Ford racing stuff. Quote Link to comment Share on other sites More sharing options...
steve-s Posted October 31, 2011 Author Report Share Posted October 31, 2011 Thanks Grabber, I'll try that and have to save up the cash for a "good" CAI. Sure wish I'd went that way instead of trying to save a buck with buying the K/N junk setup. Quote Link to comment Share on other sites More sharing options...
steve-s Posted October 31, 2011 Author Report Share Posted October 31, 2011 Steve, you can reset the dummy light by disconnecting the battery for 5 minutes and then reconnecting it. This will clear the code. If the code comes back...you have a problem that needs to be looked at. BTW get rid of the K and N product. In my opinion you should go with VMP or JLT or Ford racing stuff. Did what you said Grabber and engine check light has reset. I put the stock box back on for now. Thanks again. Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 1, 2011 Report Share Posted November 1, 2011 Did what you said Grabber and engine check light has reset. I put the stock box back on for now. Thanks again. Glad it worked out for you. Quote Link to comment Share on other sites More sharing options...
rwahl Posted August 31, 2012 Report Share Posted August 31, 2012 I had FRPP power upgrade pkg installed w/mufflers & tune by dealer -- unbelievable difference in throttle response and power -- started the dreaded axle hop! Recently got CEL and was the fuel pump pressure. At dealer now getting replacement @ 10k miles! Anyone else have this problem? Quote Link to comment Share on other sites More sharing options...
