wheelin Posted October 27, 2011 Report Share Posted October 27, 2011 If you have this setup what rim width did you go with and was a spacer needed? 315 R888 Have been done with 11 3/4 has anybody gone with 11 to 11.5 wide? thx mike Link to comment Share on other sites More sharing options...
Madlock Posted October 27, 2011 Report Share Posted October 27, 2011 If you have this setup what rim width did you go with and was a spacer needed? thx mike If you're talking about a 315/30-20, you shouldn't need any. Link to comment Share on other sites More sharing options...
dbackg Posted October 27, 2011 Report Share Posted October 27, 2011 http://www.teamshelby.com/forums/index.php?/topic/57225-traction-super-snake-wheels-and-tires/ Link to comment Share on other sites More sharing options...
Madlock Posted October 27, 2011 Report Share Posted October 27, 2011 As a side note to the above thread reference, if you're going to widen your wheels, you should probably use a spacer equivalent to half of the additional wheel width added - which will maintain the overall factory rear track. It may ALSO save you from having to cut parts off your car. Link to comment Share on other sites More sharing options...
dbackg Posted October 27, 2011 Report Share Posted October 27, 2011 11.5" wide wheel is ideal for a 315. no spacer will be necessary on a widen 20x11.5 alocoa. however, you probably will have to trim the orange rubber bump stop. also if your gt500 is lowered: http://www.teamshelby.com/forums/index.php?/topic/70963-lowering-springs-for-07-09-coupes-only/page__p__1215757&do=findComment&comment=1215757 Link to comment Share on other sites More sharing options...
AlexVogel Posted October 28, 2011 Report Share Posted October 28, 2011 11.5" wide wheel is ideal for a 315. no spacer will be necessary on a widen 20x11.5 alocoa. however, you probably will have to trim the orange rubber bump stop. also if your gt500 is lowered: http://www.teamshelb...57#entry1215757 Toyo recommends a 10.5 min, 11 middle and 11.5 as widest recommendation for 315/30/20. Using 10.5 will cause the least spacing, clearance potential issues. 315/30ZR20 (101Y) 10.5-11.0-11.5 Link to comment Share on other sites More sharing options...
Madlock Posted October 28, 2011 Report Share Posted October 28, 2011 Toyo recommends a 10.5 min, 11 middle and 11.5 as widest recommendation for 315/30/20. Using 10.5 will cause the least spacing, clearance potential issues. 315/30ZR20 (101Y) 10.5-11.0-11.5 Will cause the least LATERAL clearance issues - but MAY create height clearance issues. Link to comment Share on other sites More sharing options...
AlexVogel Posted October 29, 2011 Report Share Posted October 29, 2011 Will cause the least LATERAL clearance issues - but MAY create height clearance issues. Stock SVTPP rear tire is 27.9", 315 30 20 R888 is 27.6" - should be good Link to comment Share on other sites More sharing options...
Madlock Posted October 29, 2011 Report Share Posted October 29, 2011 Stock SVTPP rear tire is 27.9", 315 30 20 R888 is 27.6" - should be good Don't be surprised by how much taller the tire becomes on a narrower-than-spec'd wheel. Link to comment Share on other sites More sharing options...
