Fuse Help
10SHELBY
Well I had a cell phone charger plugged into my center console lighter outlet and the cheap thing came apart and blew a fuse somewhere. I've looked at the manual and I can not find the bad fuse. I really do not want to pull and check each one and I was wondering if anyone knew what fuse it is. Once again center console accessory outlet in the 2010 Shelby.
Thanks in advance,
Rudy
Thanks in advance,
Rudy
like the color combo--so the fuse depiction isnt in the manual--it has to be,otherwise how would one change fuses--il look in mine,but if its not there, id start with all the lower value fuses, like 15amp--pull them abd see if the wire in it is broken--bad fuse
Thanks in advance,
Rudy
its not there in the manual--this is my only Ford product in my gagarge, but i have a 2008 STSV Caddy (469hp)--i had a fuse go out--when i lifted off the cover to the fuses, it had fuse assigments on the inside of the cover--i dont want to start fooling with my Shelby right now, but if theres a fuse block housing, take the cover off and see if that helps
