Installation of Factory GT Spoiler - Template/ Measurements?
Hi there gang,
I'd like to install/ add the factory GT spoiler that was originally deleted from our SGT's. Does anybody have a template or the exact measurements of where the bolt holes should be drilled through the trunk lid? Thanks so much in advance! Dana
Hi there gang,
The GT spoiler and the GT-500 spoiler share the same bolt hole pattern through the trunk. As the spoiler is also a "dealer option" then I think your local Ford dealer should have the template OR it (template) may even come with the OEM Ford GT spoiler. I would be careful buying a non-Ford spoiler as there is such a variety of quality out there among the after-market crowd. Good luck with your project.
Hi and thanks for the response. Actually, I am going with another manufacturers spoiler but it does utilize the 2 original GT holes if I were to have had one mounted. That is why I was hoping someone had some measurements. I can always find my spots myself once I get the new spoiler ready to go. Dana
Dana, just an FYI, the original Ford spoilers for 2006 and 2007 use 4 holes and double face tape. regards, Larry
From trunk lid edge to the edge of the base is 8 5/8", from the rear lip to the rear base edge is 1/2". tape off the area and traced out the bases. Put the studs in the spoiler, lined it back up to the marks. 4 holes later, bit of primer and paint its on
http://www.ehow.com/how_6146709_install-rear-spoiler-2005-mustang.html
Hope it helps
