Marv Posted August 23, 2011 Report Share Posted August 23, 2011 When I purchased my car it had the quarter window trim mounted around it. I know its on with 3m tape. Is there a easy way to remove without bending trim ? Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted August 23, 2011 Report Share Posted August 23, 2011 When I purchased my car it had the quarter window trim mounted around it. I know its on with 3m tape. Is there a easy way to remove without bending trim ? You can use fishing string slide it under work it back and forth or if you have plastic trim removal tools you can use to wide ones and start from the center on one side work your way out and around the trim. Either way its a pain just dont lose your temper also make sure you put masking tape around the trim so you don't damage the paint. Good luck Quote Link to comment Share on other sites More sharing options...
Larry T Posted August 23, 2011 Report Share Posted August 23, 2011 Try using fishing line to cut the tape first, use it like a saw back and forth, and then use 3M adhesive remover to clean up. Quote Link to comment Share on other sites More sharing options...
Marv Posted August 23, 2011 Author Report Share Posted August 23, 2011 thanks guys, great advice. Will give it a try. I want to add the side window louvers instead. Quote Link to comment Share on other sites More sharing options...
cobradad Posted August 23, 2011 Report Share Posted August 23, 2011 +1. Yup what they said. I did that to remove some window wind deflectors that were starting to crack from age. As mentioned, go slow and don't rush. CC Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted August 23, 2011 Report Share Posted August 23, 2011 If all fails I say take a rope tie one end to the trim the other to a fat chick and throw a donut past her. Make sure not to get any donut powder on yourself Quote Link to comment Share on other sites More sharing options...
Marv Posted August 23, 2011 Author Report Share Posted August 23, 2011 ok your killing me ! lol Quote Link to comment Share on other sites More sharing options...
