scottma Posted March 26, 2007 Report Share Posted March 26, 2007 Is ths caused by the hydraulic assist. Would appreciate your help. Link to comment Share on other sites More sharing options...
scottma Posted March 26, 2007 Author Report Share Posted March 26, 2007 Oops almost forgot...Welcome to the forum Scottma!! :hyper: Thank you very much . I am glad to be a part of it. Link to comment Share on other sites More sharing options...
FormerGmc Posted March 26, 2007 Report Share Posted March 26, 2007 100-06A-3 Pre-Delivery - Passenger Car and Light Truck PRE-DELIVERY PROCEDURES (Continued Check Manual Transmission and Clutch NOTE: The Shelby GT500 equipped with a manual transmission may exhibit a "clutch chatter" during initial launch of the vehicle. The clutch chatter may be present in 1ST and REVERSE gears, and is considered a normal characteristic caused by the cerametallic clutch lining. The clutch chatter has no effect on the performance or durability of the vehicle. Recommend comparison to a like unit. If the symptom is excessive compared to a like unit, refer to Workshop Manual Section 308 for additional manual transmission diagnostic information. NOTE: The Shelby GT500 equipped with a manual transmission may exhibit a "clutch hiss" noise from the driveline during clutch engagement. The clutch hiss noise is most noticeable during initial engagement of the clutch into 1ST and/or REVERSE gears, and is considered a normal characteristic caused by the cerametallic clutch lining contacting the pressure plate and flywheel metal surfaces. The clutch hiss noise has no effect on the performance or durability of the clutch or transmission. Recommend comparison to a like unit. If the symptom is excessive compared to a like unit, refer to Workshop Manual Section 308 for additional manual transmission diagnostic information. NOTE: The Shelby GT500 equipped with a manual transmission may exhibit a light "gear rollover" noise while the clutch is engaged and the transmission is in NEUTRAL. Gear rollover noise is a normal characteristic under these condition. If the noise is believed to be abnormally loud, compare to a like unit before attempting any repair. Refer to Workshop Manual Section 308 for additional manual transmission diagnostic information. NOTE: The Shelby GT500 equipped with a manual transmission may exhibit a "gear rattle" noise from the driveline during 1ST and 2ND gear slow or gradual launch of the vehicle. The gear rattle noise is only present in 1ST and 2ND gears and is considered a normal characteristic caused by contact pattern. The gear rattle noise has no effect on the performance or durability of the vehicle. Recommend comparison to a like unit. If the symptom is excessive compared to a like unit, refer to Workshop Manual Section 308 for additional manual transmission diagnostic information. Link to comment Share on other sites More sharing options...
Grabber Posted March 26, 2007 Report Share Posted March 26, 2007 When I took my Shelby out of the shop today to go for a ride, the first thing I noticed was the hiss. That is so darn cool. What a great way to start out your ride. I had to mow the yard and field today, but the weather held for a great 25 mile ride. Funny how my Harley Davidson has now taken the back seat of my riding choices. At least till it gets warmer. Link to comment Share on other sites More sharing options...
b17drvr Posted March 26, 2007 Report Share Posted March 26, 2007 Gee, I thought it made the hissing noise because it is a Cobra... Link to comment Share on other sites More sharing options...
carlo Posted April 19, 2007 Report Share Posted April 19, 2007 hey when the hiss stops like it did on mine you're in trouble...I lost my slave and master hydraulic cylinder monday...they just died.... Link to comment Share on other sites More sharing options...
Son of GT Posted April 20, 2007 Report Share Posted April 20, 2007 hey when the hiss stops like it did on mine you're in trouble...I lost my slave and master hydraulic cylinder monday...they just died.... Did the clutch pedal go soft and floppy on you? Did you get any Hyd. fluid leaking through the firewall? And no, I'm not trying to be funny. I'm asking a straight question that just sounds funny. Thanks. Link to comment Share on other sites More sharing options...
TexasShelby Posted May 15, 2007 Report Share Posted May 15, 2007 Out here in the desert.... you'll never see a snake that doesn't HISSSSS a little before he strikes! Great sound, I would have worked that into the marketing somehow. Link to comment Share on other sites More sharing options...
