2011 CPS question
fgrdods
I have a 2011 GT500 and noticed that the Cam Position Sensor appears to be allowing oil to seep out onto the head. (I am pretty sure it is the CPS.) I suspect that it is a simple o-ring, but wanted to check and see if this is a known or common problem.
Has anyone noticed anything similar?
Thanks.
Thanks.
Is the bolt that holds the CMP Sensor in, tight?
And yes, as far as I know it's just a o-ring (vs. a quad ring).
Phill
Mine is the drivers side. Sure it's not a big deal, just wanted to check to see if others have the same thing. Gonna remove and inspect it tonight.
Correct, "right" and "left" on a car are respective to sitting in the drivers seat.
The Cmp Sensor is on the front fo the left side head, behind/under the PS reservoir.
Phill
