Toy Cobra Posted August 10, 2011 Report Share Posted August 10, 2011 I have not seen any discussions about the problem of differential fluid venting out while doing high speed track touring. Mine is a 2011 Gt500, 3.73 gears, FRPP setup. Took it to the dealer, they said I need to check into a different differential fluid like Lucas Oil. Anyone out there having this problem and what have you tried? Does anyone have a catch can setup on the bleeder vent? Does anyone have a differential cooler? Thanks. Link to comment Share on other sites More sharing options...
Curt A Posted August 10, 2011 Report Share Posted August 10, 2011 http://www.teamshelby.com/forums/index.php?/topic/53848-tsb-10-3-7-rear-drive-axle-ventoil-leak/page__p__913957__hl__%2Brear+%2Baxle+%2Boil+%2Bleak__fromsearch__1#entry913957 Link to comment Share on other sites More sharing options...
Tob Posted August 18, 2011 Report Share Posted August 18, 2011 http://www.svtperformance.com/forums/10751356-post11.html Link to comment Share on other sites More sharing options...
jacks1071 Posted August 19, 2011 Report Share Posted August 19, 2011 I have not seen any discussions about the problem of differential fluid venting out while doing high speed track touring. Mine is a 2011 Gt500, 3.73 gears, FRPP setup. Took it to the dealer, they said I need to check into a different differential fluid like Lucas Oil. Anyone out there having this problem and what have you tried? Does anyone have a catch can setup on the bleeder vent? Does anyone have a differential cooler? Thanks. The Falcon's in Australia have the same issue, the differential cooler fixes it. Link to comment Share on other sites More sharing options...
dbackg Posted August 19, 2011 Report Share Posted August 19, 2011 I have the KR reservoir. Fit is good and works great. I like the BOSS blader. Thanks for that SVT link. I have never seen a diff cooler installed on a Mustang. Link to comment Share on other sites More sharing options...
Tob Posted August 19, 2011 Report Share Posted August 19, 2011 I have never seen a diff cooler installed on a Mustang. http://rehagenracingproducts.com/product.sc?productId=753&categoryId=14 Link to comment Share on other sites More sharing options...
dbackg Posted August 20, 2011 Report Share Posted August 20, 2011 thanks Tob. Link to comment Share on other sites More sharing options...
SSGT500 Posted August 20, 2011 Report Share Posted August 20, 2011 I had a similar problem on my 2007. The TSB bladder vent solved it. If you're running an aftermarket tune, it can cause the entire exhaust to run hot and raise the temp of the rear axle in a track situation. Link to comment Share on other sites More sharing options...
