RWJon Posted August 9, 2011 Report Share Posted August 9, 2011 My '11 350 just turned 900 miles. For the past couple of months, I have been experiencing a vibrating sound coming from the rear end while acceleration. When 'cruising', it is not there. A couple of very good mechanics at the local Ford garage spent an hour with it and seemed to have found the culprit...the original, rear bumper brackets. Not sure if this is the problem, but we are going to wrap and see if this eliminates the noise. Has anyone else been experiencing a similar noise in their 350? Quote Link to comment Share on other sites More sharing options...
DubbsFaris Posted August 11, 2011 Report Share Posted August 11, 2011 You might check the exhaust pipe on the drivers side hitting the rear axle under heavy acceleration. It has to be adjusted at the fitting just behind the header to give you the roper spacing at the bend at the axle. Ive seen two cars with that problem.... Quote Link to comment Share on other sites More sharing options...
