johnrehder Posted July 14, 2011 Report Share Posted July 14, 2011 So I have an exhaust leak close to the header. I'm taking it to a dealer for an estimate to fix it tommorow. If its a lot of money to fix it I might as well put long tube headers on. Is there a set up that will allow me to stay emissions legal? I'm in a county that requires emissions tests each year. Do I need to keep the cats?? Looking for any advice. thanks Link to comment Share on other sites More sharing options...
Jer Posted July 14, 2011 Report Share Posted July 14, 2011 So I have an exhaust leak close to the header. I'm taking it to a dealer for an estimate to fix it tommorow. If its a lot of money to fix it I might as well put long tube headers on. Is there a set up that will allow me to stay emissions legal? I'm in a county that requires emissions tests each year. Do I need to keep the cats?? Looking for any advice. thanks Is it near the cut-in X-pipe? Might be a simple fix, tighten the bolts a bit. Jer Link to comment Share on other sites More sharing options...
young768 Posted July 14, 2011 Report Share Posted July 14, 2011 John, The exhaust system is bolted together at each joint so hopefully it may just be a leak at a loose joint as Jer indicated. To pass emissions, you will have to have the cats otherwise it will fail and I believe it is actually illegal in GA to run without the cats unless it is an off road vehicle. Robert Link to comment Share on other sites More sharing options...
johnrehder Posted July 14, 2011 Author Report Share Posted July 14, 2011 Sounds like a leak by where the header meets the down pipe before the cat. I don't have a lift so I could'nt point it out. Is it near the cut-in X-pipe? Might be a simple fix, tighten the bolts a bit. Jer Link to comment Share on other sites More sharing options...
