Steeda Radiator Cover?
I like the idea of the Steeda brushed radiator cover (the bigger one that covers the "top section"), but I can't tell if it will clear the hood pin brackets on an SGT. Looks like it might...
I think it would look great with my Moroso tanks.
I also expect to mount it with Velcro or something similar, as opposed to silicone goop, so it's removeable if I need to get the cover off at any point. That alone might raise the front lip edge enough to clear the brackets.
Jer
http://www.steeda.com/store/steeda-stainless-steel-radiator-covers-for-2005-thru-2009-ford-mustang.html
Stick it on, then drill and dremel from the back till it has the same openings as the plastic cover.
I thought about that, but I bet if I cut it the heat discolors it.
Thoughts?
Jer
its an overlay so it should work I would glue it together with silicone
Do you think it would pull free if I use LOTS of Industrial Strength Velcro?
Jer
