KR158 Posted May 31, 2011 Report Share Posted May 31, 2011 Took the car out this weekend and was having lots of belt slip issues. In 2nd gear was fine but around 5k plus in 3rd would get the belt noise and lose boost and car would fall on its face until I grabbed fourth. I am running the vmp tvs with 10% lower and never had the issue the last 2-3 times out since install. Also running the 90mm idler Justin sells. Car has maybe 500 miles on new set up and 3k total on belt etc. Any ideas or help would be great. Want to add more power with JLT cai and longtubes but fear it will only make belt issue worse. Link to comment Share on other sites More sharing options...
KR158 Posted June 2, 2011 Author Report Share Posted June 2, 2011 Any one have any ideas on what it is if not the belt, seen this before etc? Link to comment Share on other sites More sharing options...
Seahorse Posted June 2, 2011 Report Share Posted June 2, 2011 What belt are you running? I've read elsewhere that some have had better luck with belt slip issues when switching to the Dayco Gold Polycog version. Link to comment Share on other sites More sharing options...
svtbird91 Posted June 8, 2011 Report Share Posted June 8, 2011 Running such a small upper pulley as a 2.5 is most likely the reason for the belt slippage. There's just not enough "belt wrap" considering the power demands put on it. IMO anything smaller than a 2.7 or maybe even a 2.8 will result in shortened belt life due to inadaquate belt wrap leading to permature belt slippage which results in excessive wear on the belt. Link to comment Share on other sites More sharing options...
notstock Posted June 11, 2011 Report Share Posted June 11, 2011 Did you get the problem resolved yet? Link to comment Share on other sites More sharing options...
08KR525 Posted June 13, 2011 Report Share Posted June 13, 2011 VMP is now selling a better belt that was featured in one of the Mustang magazines this month. I believe it's called a green belt or something. It is supposed to address the very issue you are having. Link to comment Share on other sites More sharing options...
hunters1 Posted September 29, 2015 Report Share Posted September 29, 2015 Look at carbonite coating your pulley Link to comment Share on other sites More sharing options...
2007red40thGT500 Posted September 29, 2015 Report Share Posted September 29, 2015 Running such a small upper pulley as a 2.5 is most likely the reason for the belt slippage. There's just not enough "belt wrap" considering the power demands put on it. IMO anything smaller than a 2.7 or maybe even a 2.8 will result in shortened belt life due to inadaquate belt wrap leading to permature belt slippage which results in excessive wear on the belt. is this your opinion or is it backed by facts? there are an awful lot of folks running upper pulleys smaller than 2.7". Link to comment Share on other sites More sharing options...
kawwy600 Posted October 9, 2015 Report Share Posted October 9, 2015 I don't know about a 2.5 inch pulley on a TVS but I have a 2.5" on my stock blower and I've had 0 issues Link to comment Share on other sites More sharing options...
Robert M Posted October 9, 2015 Report Share Posted October 9, 2015 Took the car out this weekend and was having lots of belt slip issues. In 2nd gear was fine but around 5k plus in 3rd would get the belt noise and lose boost and car would fall on its face until I grabbed fourth. I am running the vmp tvs with 10% lower and never had the issue the last 2-3 times out since install. Also running the 90mm idler Justin sells. Car has maybe 500 miles on new set up and 3k total on belt etc. Any ideas or help would be great. Want to add more power with JLT cai and longtubes but fear it will only make belt issue worse. Scroll down in the belt length guide linked below to verify the correct belt length for your S/C pulley combination. http://www.revanracing.com/products/gates-belts.html You should be able to identify what belt number is currently on your car, and compare with what is listed in the link above.............if your pulley combination is listed. R Link to comment Share on other sites More sharing options...
ICOOLUM Posted December 24, 2015 Report Share Posted December 24, 2015 You can add a upper tensioner. I got an adjustable one from Steeda about $250 easy install. Should take care of your issue rather simply Link to comment Share on other sites More sharing options...
