DougD Posted May 18, 2011 Report Share Posted May 18, 2011 Just trying to break in the the extreme brakes I installed and after about 300 miles I am still noticing a rotational rub from the rear brakes only, when I turn a corner. I have been doing some 100% braking from 100 mph and the brakes respond great, but I am wondering about this rub after the brakes are warmed up. Any adivce? Doug 07XL0218 Quote Link to comment Share on other sites More sharing options...
SSSNAKE Posted May 19, 2011 Report Share Posted May 19, 2011 Just trying to break in the the extreme brakes I installed and after about 300 miles I am still noticing a rotational rub from the rear brakes only, when I turn a corner. I have been doing some 100% braking from 100 mph and the brakes respond great, but I am wondering about this rub after the brakes are warmed up. Any adivce? Doug 07XL0218 Just to drill down; Did this rub start only after the extreme install? BTW, welcome to the 40th bast@*$ childrens club! Quote Link to comment Share on other sites More sharing options...
DougD Posted May 21, 2011 Author Report Share Posted May 21, 2011 Just to drill down; Did this rub start only after the extreme install? BTW, welcome to the 40th bast@*$ childrens club! Yes, the rub started after the install. I had it out again and did 4 brake stand stops from 100+ mph and got the brakes smoking, seems to have helped. Back in town today and I will try some more if I still get some rubbing. Doug Quote Link to comment Share on other sites More sharing options...
dbackg Posted May 21, 2011 Report Share Posted May 21, 2011 "Burnish" your brakes: http://www.fordgt.com/forums/showthread.php?20357-How-many-of-you-have-Burnished-your-Brakes&highlight=burnish+brake+pad Clutch & Brake fluid: http://www.fordgt.com/forums/showthread.php?21806-Clutch-and-Brake-Fluid Quote Link to comment Share on other sites More sharing options...
Robert M Posted May 21, 2011 Report Share Posted May 21, 2011 (edited) Just trying to break in the the extreme brakes I installed and after about 300 miles I am still noticing a rotational rub from the rear brakes only, when I turn a corner. I have been doing some 100% braking from 100 mph and the brakes respond great, but I am wondering about this rub after the brakes are warmed up. Any adivce? Doug 07XL0218 If it is the Baer Extremes you are asking about, here is a link to the Baer site, they would be the best people to answer the questions you have about their brakes. I believe that the 4th option "Rotor Seasoning" and the 3rd option "Pad Bedding" would be of interest to you. http://www.baer.com/index.php?option=com_content&view=category&id=209&Itemid=4 Hmmmmm, this would be some good info. to include in a Super Snake owners manual............. R Edited May 21, 2011 by Robert M Quote Link to comment Share on other sites More sharing options...
dbackg Posted May 22, 2011 Report Share Posted May 22, 2011 Hmmmmm, this would be some good info. to include in a Super Snake owners manual............. Quote Link to comment Share on other sites More sharing options...
DougD Posted May 22, 2011 Author Report Share Posted May 22, 2011 Thanks for the links, I have been doing all the seasoning and bedding as per Baer recommendations but they are still rubbing a bit. The box that the brakes came in actually had the procedure in it, so I have been following the procedure using the same instructions you see on the Baer site. I have also tried driving a bit with the E brake thinking that it could also be causing the rub. Doug Quote Link to comment Share on other sites More sharing options...
