GRAYPNY Posted May 6, 2011 Report Share Posted May 6, 2011 I have the GT/CS fascia on my car and was wondering how the lower billet grille installed? It looks like I have to get it in the air and remove the lower shroud to access the the mounting points. Is there anyway that I can get this grille mounted without having to do that? Link to comment Share on other sites More sharing options...
Jer Posted May 6, 2011 Report Share Posted May 6, 2011 I have the GT/CS fascia on my car and was wondering how the lower billet grille installed? It looks like I have to get it in the air and remove the lower shroud to access the the mounting points. Is there anyway that I can get this grille mounted without having to do that? Ramps are best, since you do have to take the shroud off to get back there... Once you do, it's easy - just pry off the "honeycomb" outer trim pieces, position the grille from behind the opening, and drill the holes to either put rivets thru or (as *I* did) use nuts and bolts to mount it. Then the honeycombs snap back into place. Not difficult at all. Jer Link to comment Share on other sites More sharing options...
GRAYPNY Posted May 6, 2011 Author Report Share Posted May 6, 2011 I just found a thread by Grabber where he went in from the front. I believe that the way I wnat to attach it also. Link to comment Share on other sites More sharing options...
jmn444 Posted May 6, 2011 Report Share Posted May 6, 2011 I went from the front, just drilled thru the bumper cover and the new grill as held in place rather than try to use the pre drilled holes, seemed simpler. Link to comment Share on other sites More sharing options...
07SGT Posted May 6, 2011 Report Share Posted May 6, 2011 There was another sticky thread posted by Bud from SAI years ago giving detailed instructions. Link to comment Share on other sites More sharing options...
