c43t Posted May 5, 2011 Report Share Posted May 5, 2011 Hello I cant get a new tune because i have a wrong strategy code in my car its FOASCB7 and they havent seen this before at SCT. I have put new hotrod cams and ford racing inlet and 62mm throttle on it. Has anybody done this and get new tunes? Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted May 5, 2011 Report Share Posted May 5, 2011 The correct strategy for the Shelby GT is FPASU9. The strategy listed on the ECU of the SGT is incorrect. Quote Link to comment Share on other sites More sharing options...
c43t Posted May 5, 2011 Author Report Share Posted May 5, 2011 Hello thanks for your answer. I just think its strange that me and my friends car have the same strategy code. Both of the car is shelby GT 2008 4,6L automatic transmission. Quote Link to comment Share on other sites More sharing options...
JeffJ Posted May 5, 2011 Report Share Posted May 5, 2011 (edited) What tuner are you using? Or do you not have one yet? Very likely, the strategy on the white tag on your computer, is not the strategy which is actually there. At least that was the case with my 2006. Shelby changed the strategy from stock when they made their upgrades. I'm not sure if that's the case or not on your 2008. Anyhow once you have your tuner, you can plug that in and it will give you the correct strategy on your car to use as stock. Once I got my SCT tuner from Bama Chips, I then plugged it in to get my proper strategy to let Bama know. They then sent me the tunes via e-mail to update the tuner based on that strategy. I would start with the strategy from El Shelby above, and then once you have your tuner, if that is not the proper one on your car, then they can just send you updated files based on that. The number you provided in the first e-mail above, just does not look right to me. Most of the 2005+ strategies are only 6 digits to my knowledge, but I could be wrong. PS, I'm loving my Hot Rod cams. Edited May 5, 2011 by JeffJ Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted May 5, 2011 Report Share Posted May 5, 2011 All Shelby GT's have the same strategy. Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted May 6, 2011 Report Share Posted May 6, 2011 (edited) I bet if you call John Lund, he can fix it up for you. http://lundracing.com/ Edit: Added link. Edited May 6, 2011 by 07SGT4578 Quote Link to comment Share on other sites More sharing options...
