Dlancer Posted May 4, 2011 Report Share Posted May 4, 2011 I have Shelby GT #1385. I have had a noise when going over bumps since I bought the car last June. I have had it to two Ford dealerships. The first could find nothing wrong. The second had the car for three days and the only thing they did was lube all the parts in the rear supension. It was better for just a couple of weeks but has come back. The noise is less noticeable if it is raining or wet out. Has anyone else had this problem with there car and what was the fix that finally got rid of it. Thanks for any insight. Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted May 4, 2011 Report Share Posted May 4, 2011 I have Shelby GT #1385. I have had a noise when going over bumps since I bought the car last June. I have had it to two Ford dealerships. The first could find nothing wrong. The second had the car for three days and the only thing they did was lube all the parts in the rear supension. It was better for just a couple of weeks but has come back. The noise is less noticeable if it is raining or wet out. Has anyone else had this problem with there car and what was the fix that finally got rid of it. Thanks for any insight. I had the same problem. Basically Ford says the suspension pack is prone to this and is expected. There are several topics on this subject. Basically it helps to lube some of the dry bushings. I don't have time to find the topic right now but it is in the SGT tech area. Quote Link to comment Share on other sites More sharing options...
Jer Posted May 4, 2011 Report Share Posted May 4, 2011 I had the same problem. Basically Ford says the suspension pack is prone to this and is expected. There are several topics on this subject. Basically it helps to lube some of the dry bushings. I don't have time to find the topic right now but it is in the SGT tech area. Mine was at the swaybar link bushings (where the red bushings hold the blue swaybar). WD40 every once in a while, noise is gone. Jer Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted May 4, 2011 Report Share Posted May 4, 2011 Mine was at the swaybar link bushings (where the red bushings hold the blue swaybar). WD40 every once in a while, noise is gone. Jer Yep, that's it - they bind up and "snap" when they release. Someone suggested using anti-seize as a lubricant. Quote Link to comment Share on other sites More sharing options...
Blown Away Posted May 5, 2011 Report Share Posted May 5, 2011 Mine is starting to have an erratic "chirp" once in a while when hitting a bump in the road. It started after my trip to Bakersfield the week before the Fabulous Fords Show. Guess it's time to put it on the lift and lube it up... Dan Quote Link to comment Share on other sites More sharing options...
fatboy Posted May 10, 2011 Report Share Posted May 10, 2011 thats normal for polyurethane bushings. just lube them once in a while. not sure but i thought i read somewhere on this forum that someone made it easier by putting in zerks so they can hit them with a grease gun. can anyone chime in on that? Quote Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted May 11, 2011 Report Share Posted May 11, 2011 Yep, that's it - they bind up and "snap" when they release. Someone suggested using anti-seize as a lubricant. Seems like I remember Springer taking his apart and using motorcycle anit-seizing stuff of some sort, don't have time to search it. I lube mine with WD40 from time to time. Considered normal in the SGT Owners Manual. GG Quote Link to comment Share on other sites More sharing options...
