Speed Racer Posted April 24, 2011 Report Share Posted April 24, 2011 As everyone already knows the factory guards do not stop stones from tearing up the plastic rockers or prevent stone chipsin the lower doors especially with the F1 G2 tires. Here is a great solution that I found that is cost effective easy to install and uses the factory mounting hardware. Two clips are provided for the fronts. Check out the link below. They work and are hardly noticeable when installed. I installed mine in 15 minutes and did not have to take off the wheels. http://rpidesigns.com/shop/item.aspx?itemid=1926 Quote Link to comment Share on other sites More sharing options...
gr8snkbite Posted April 24, 2011 Report Share Posted April 24, 2011 Nice speedy......I like and prefer JLT's CF version better tho...... Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted April 24, 2011 Report Share Posted April 24, 2011 As everyone already knows the factory guards do not stop stones from tearing up the plastic rockers or prevent stone chipsin the lower doors especially with the F1 G2 tires. Here is a great solution that I found that is cost effective easy to install and uses the factory mounting hardware. Two clips are provided for the fronts. Check out the link below. They work and are hardly noticeable when installed. I installed mine in 15 minutes and did not have to take off the wheels. http://rpidesigns.com/shop/item.aspx?itemid=1926 I used Jaeger Brothers. Just another alternative. http://jaegerbrothersauto.com/parts/Splash%20Guards_81/ Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted April 27, 2011 Report Share Posted April 27, 2011 Are any of these wider than the stock ones? I need something a little wider. Rudy Quote Link to comment Share on other sites More sharing options...
wanted2b Posted April 29, 2011 Report Share Posted April 29, 2011 JTL can't get the ones for the 2012s. I'm on their list for a set. They look like they might work. The supplier is in the process of making them now. Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted April 30, 2011 Report Share Posted April 30, 2011 Are any of these wider than the stock ones? I need something a little wider. Rudy I just needed the front ones on my 2010. They mount right on using the existing hardware on car and yes, they are wider but not obnoxiously wider. I live in Nebraska where we have a gravel problem on the highways and they work great. I have 4500 miles on my car and they have protected the area immediatly behind the front tire, stripe & paint. Quote Link to comment Share on other sites More sharing options...
kwenarch Posted May 2, 2011 Report Share Posted May 2, 2011 I just needed the front ones on my 2010. They mount right on using the existing hardware on car and yes, they are wider but not obnoxiously wider. I live in Nebraska where we have a gravel problem on the highways and they work great. I have 4500 miles on my car and they have protected the area immediatly behind the front tire, stripe & paint. yeah just put mine on and really like them, i didnt want the rears as i think the factory ones cover enough and look better. Covered them in flat black vinyl and the look perfect as cf doesnt match the factory rears Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted May 2, 2011 Report Share Posted May 2, 2011 yeah just put mine on and really like them, i didnt want the rears as i think the factory ones cover enough and look better. Covered them in flat black vinyl and the look perfect as cf doesnt match the factory rears 10-4. I have no problem with chips, etc on the rear 1/4's. This forum is great for sharing this information. I wouldnt have known about the front ones without this exhange of ideas. Quote Link to comment Share on other sites More sharing options...
gotvenm Posted May 3, 2011 Report Share Posted May 3, 2011 JTL can't get the ones for the 2012s. I'm on their list for a set. They look like they might work. The supplier is in the process of making them now. They show on their site that 2010-2012 is in stock, your post makes it seem like the 2012's are different? You cant choose a particular year when ordering... Quote Link to comment Share on other sites More sharing options...
wanted2b Posted May 3, 2011 Report Share Posted May 3, 2011 They only have the front now. When I talked to them a week ago their vendor had not produced them and they were waiting on a shipment. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
