07SGT5687 Posted April 11, 2011 Report Share Posted April 11, 2011 (edited) So recently I've purchased the first few covers and tanks that I've owned that are made from welded aluminum. While I ordered several of these pieces from different vendors, they all did come from Moroso. So I'm curious, is this white frosty haze around all the welds normal? Just looks kinda crappy to me, but maybe... once again... my standards were artificially high. Thoughts? I might go with black powder coated equipment if this the way they are always going to look. Again, I mean this as no reflection on the vendors I actually bought them from. In one case already, SPP jumped at the opportunity to make it right (and went far beyond what I would have considered adequate!) Edited April 11, 2011 by 07SGT5687 Quote Link to comment Share on other sites More sharing options...
car dude Posted April 11, 2011 Report Share Posted April 11, 2011 I am not a welder but it looks like they sanded the metal before they welded it. or it might be oxidation from gas that is use when welding. Does rubbing remove any of it? Quote Link to comment Share on other sites More sharing options...
08sgt1042 Posted April 12, 2011 Report Share Posted April 12, 2011 that frosty look happens in the process of TIG welding the aluminum. the only way to get rid of it would be in the cleaning process prior to clading or the coating of the finishes product. J R is the finishes coated with a clear coat? if so it wont just come off I would think you will have to clean off the finish and then clean the metal and then re-coat, I welded for years on Aluminum and it is normal.....sorry Quote Link to comment Share on other sites More sharing options...
07SGT5687 Posted April 12, 2011 Author Report Share Posted April 12, 2011 that frosty look happens in the process of TIG welding the aluminum. the only way to get rid of it would be in the cleaning process prior to clading or the coating of the finishes product. J R is the finishes coated with a clear coat? if so it wont just come off I would think you will have to clean off the finish and then clean the metal and then re-coat, I welded for years on Aluminum and it is normal.....sorry Thanks Mick. I thought it might be usual. I just hadn't seen it up close and personal. Think I still might look for some black PC'd stuff though. Looks cleaner. Quote Link to comment Share on other sites More sharing options...
08sgt1042 Posted April 12, 2011 Report Share Posted April 12, 2011 JR what all did you get for tanks? I am actually staying with the Aluminum look under the hood being as my ride is vista blue can you show me the full view of the tanks? If you want to off load them I might be interested.... Quote Link to comment Share on other sites More sharing options...
