Frederic Dumong Posted April 2, 2011 Report Share Posted April 2, 2011 hi everyone- It seems to be strange but this is a true problem for me In our country hood pins aren't allowed on a car as, the risk of injuries when you hit someone blablabla,...So my question is as follows. do you have any idea where I can find some kind of plastic cover or protection, to put over the hoodpins. Important is, that it should be easy to fix and to remove. I need this cover just the day when I must present the car at the technical control, so it is once a year, and every year. (...and I honestly don't wanna remove the hoodpins every year. So a plastic cover that I can fix with double side tape or like a magnet. I know this is not so easy, but maybe someone of you all can help me or give me the right idea, about what I can do. Maybe this item already exists, and someone knows it. Thanks in advance, all help is appreciate. Greetings Fred Quote Link to comment Share on other sites More sharing options...
socalwrench Posted April 2, 2011 Report Share Posted April 2, 2011 Double post? Never heard of a hood pin cover, but if it's only a yearly inspection- maybe just swap out hoods for the day. Quote Link to comment Share on other sites More sharing options...
FordRocks1 Posted April 2, 2011 Report Share Posted April 2, 2011 Plenty of s197 hoods laying around, that's probably your best bet. Removing and installing these hood pins on these flimsy hood will cause the screw to mess with the material to where the threads are no good. Quote Link to comment Share on other sites More sharing options...
