Replacemt lower grille install
07 Black Beauty
Was looking to install a replacement lower grille and was wondering the best way to get the stock lower grille off?
I assume you are talking about a GT500? This may not be the simplest way, but the way that I did it was to first remove the front bumper cover. Then you have easy access to the back side of the grill and you can carefully (although it is a PITA) manipulate the tabs to release the lower grill. Removing the front bumper cover is easier than you think. You can look at the instructions that Van provides for installing his upgraded radiator and heat exchanger to see how to do it. They are in post #4 here: http://www.teamshelby.com/forums/index.php?/topic/41274-revan-racing-heat-exchanger-installation/.
