motormouth Posted February 18, 2011 Report Share Posted February 18, 2011 I have been getting a rusty spring sound from my rear end when going over bumps. Have car at shop now he has checked lower control arms, shocks, upgraded sway bars, and link, all are good. Hasn't made it to upper link yet (going to do in morning) I am sure someone here has already had this fixed and would like to see what they found. Link to comment Share on other sites More sharing options...
07SGT4578 Posted February 18, 2011 Report Share Posted February 18, 2011 Maybe you should check to see if the exhaust is getting in a bind and hitting. Chris Link to comment Share on other sites More sharing options...
snatchss454 Posted February 20, 2011 Report Share Posted February 20, 2011 Is it like a creaking sound? I had something similar and thought it was my LCA's or driver side rear spring perch. When I would accelerate and the weight would transfer from front to rear I would get the creaking sound. I had Griggs adjustable LCA's installed along with a J&M adjustable UCA and when the tech got to the UCA he noticed that the UCA bushing on top of the diff was wasted. This caused havoc for me for a long time, I had driveshaft vibration, creaking, LOUD metal on metal banging sound when I downshift from a 60mph roll and punch it. Check the mount. HTH's, Shane Link to comment Share on other sites More sharing options...
cloud9 Posted February 20, 2011 Report Share Posted February 20, 2011 Is it like a creaking sound? I had something similar and thought it was my LCA's or driver side rear spring perch. When I would accelerate and the weight would transfer from front to rear I would get the creaking sound. I had Griggs adjustable LCA's installed along with a J&M adjustable UCA and when the tech got to the UCA he noticed that the UCA bushing on top of the diff was wasted. This caused havoc for me for a long time, I had driveshaft vibration, creaking, LOUD metal on metal banging sound when I downshift from a 60mph roll and punch it. Check the mount. HTH's, Shane I have the same creaking sound from the driver's side rear spring on my Griggs GR40SS. I only hear it a low speeds going over bumps. I have a torque arm so no UCA. I have checked all the bushings and I don't see any that are cracked or deformed. I have had a rattle from what sounds like the passenger side spring area since day one but can't find anything loose. I wonder if it's not the Watts Link heim joints? I don't have any noticeable issues other than those two noises over low speed bumps. Link to comment Share on other sites More sharing options...
motormouth Posted February 21, 2011 Author Report Share Posted February 21, 2011 The shop found it finally, it was the upper link of the sway bar. A bad connector, replaced and back to normal over bumps! Thanks for the replies. H Link to comment Share on other sites More sharing options...
cloud9 Posted February 27, 2011 Report Share Posted February 27, 2011 The shop found it finally, it was the upper link of the sway bar. A bad connector, replaced and back to normal over bumps! Thanks for the replies. H Bad connector as in a cracked bushing? Link to comment Share on other sites More sharing options...
