Differential fuid/oil
Firekiller
Hello guys, One question for you all. After all the discussion on engine oil and trans oil, I have decided to go with the redline and amsoil tranny fluid, but what was mentioned about the rear diff fluid. I cant remember after all the different threads and topics on them which one was mentioned. Could someone post up what the best diff fluid was please and thank you.
Royal Purple.
I had a Trans Am with 75K miles on it. I put RP 75W-140 in it, and in another 10K miles the pinion bearing spun and the rear-end had to be re-built, and it looked like there had been a lot of heat in there as the gears were discolored in a way they weren't when the RP went in.
Was it the RP? No way to know. I just know I don't plan on using it anymore. Factory fill is just fine. I have never heard of a rear-end wearing out due to lubricant failure when filled correctly with the correct fluid. Same for engines, transmissions, and anything else requiring lube.
A perfect example are my AR-15's. The military uses CLP. They have M16's that have gone through numerous barrels. Yet I use LaRue MG lube, or other proprietary blends. Because it makes me feel better. My AR's have been 100% except for one Colt CAR-15 A3 which had seen well over 1000 rounds between lube/cleanings, and that same rifle again when firing non full-length resized reloads through it (fail on my Dad's part).
I guess my point is, there is a lot of debate over how to prevent 2-5% wear on a part that will outlast the rest of the car. Much like wrapping an anvil in velvet and not wearing gloves to hold the hammer.
