Bassaholic Posted January 25, 2011 Report Share Posted January 25, 2011 So my shelby has been sitting for about 6 months and finally got it out and drove it. Well I decided to put a fuel additive in it since it had been sitting so long (some type of fuel injection cleaner) and I guess that was a bad idea. I now have a check engine light and my fuel gauge shows half full even though i know i filled it up. So I have gone through atleast one tank of fuel and refilled and the light wont go away. Anybody else make this mistake like me and did you have to take it to ford to get it fixed or did it eventually go away? Im gonna pull the code again b/c i cant remember. Ill post it up in 5 min. Quote Link to comment Share on other sites More sharing options...
Bassaholic Posted January 25, 2011 Author Report Share Posted January 25, 2011 well now it wont pull the code. Last time it had gone away when I got down to about a 1/4 of a tank left but came back after i filled up. But i remember it being some sensor in the gas tank but cannot remember the code number. Its at 1/4 tank now so im gonna run it out and refill and see if it comes back. Just wanted to know if anybody else had this problem. Quote Link to comment Share on other sites More sharing options...
Craigo Posted January 25, 2011 Report Share Posted January 25, 2011 well now it wont pull the code. Last time it had gone away when I got down to about a 1/4 of a tank left but came back after i filled up. But i remember it being some sensor in the gas tank but cannot remember the code number. Its at 1/4 tank now so im gonna run it out and refill and see if it comes back. Just wanted to know if anybody else had this problem. I store her with a full tank and a gas stabilizer. I'm not sure if that's the same as a cleaner. I know I stored a 1/2 tank of gas for my outboard without a stabilizer and in the spring in had an inch of water floating on top. That's because of the new gas/alcohol mixture now days. The alcohol pulls moisture out of the air. Quote Link to comment Share on other sites More sharing options...
FiaCobra Posted January 25, 2011 Report Share Posted January 25, 2011 Try disconnecting the battery for 5 minutes. Reconnect, and take the car out for a nice long drive (at least 25 miles) Quote Link to comment Share on other sites More sharing options...
interceptor Posted January 25, 2011 Report Share Posted January 25, 2011 well now it wont pull the code. Last time it had gone away when I got down to about a 1/4 of a tank left but came back after i filled up. But i remember it being some sensor in the gas tank but cannot remember the code number. Its at 1/4 tank now so im gonna run it out and refill and see if it comes back. Just wanted to know if anybody else had this problem. You didn't do anything wrong,you just need to do one more thing. Add some TECHRON fuel treatment Today's fuel varnishes real easy and fuel stabilizer doesn't help for this problem once it's on there.It will take a while to clean the varnish on the sending unit but it should be ok with some driving.I would advise using it every once in a while even in the driving season as it will further prevent it from happening again. Quote Link to comment Share on other sites More sharing options...
Bassaholic Posted January 25, 2011 Author Report Share Posted January 25, 2011 You didn't do anything wrong,you just need to do one more thing. Add some TECHRON fuel treatment Today's fuel varnishes real easy and fuel stabilizer doesn't help for this problem once it's on there.It will take a while to clean the varnish on the sending unit but it should be ok with some driving.I would advise using it every once in a while even in the driving season as it will further prevent it from happening again. http://www.amazon.com/Chevron-Techron-Fuel-System-Cleaner/dp/B00092893E Is that the right cleaner? Also ill try the battery disconnect and a good drive as well. Anything from going to the dealership. I just don't want them to check codes and find out there was a sct tune on it just a few hours before lol. Quote Link to comment Share on other sites More sharing options...
interceptor Posted January 25, 2011 Report Share Posted January 25, 2011 http://www.amazon.com/Chevron-Techron-Fuel-System-Cleaner/dp/B00092893E Is that the right cleaner? Also ill try the battery disconnect and a good drive as well. Anything from going to the dealership. I just don't want them to check codes and find out there was a sct tune on it just a few hours before lol. Yes, that is it and it is recommended by Ford! Quote Link to comment Share on other sites More sharing options...
supercompdad Posted January 26, 2011 Report Share Posted January 26, 2011 Yes, that is it and it is recommended by Ford! On the shelf at any O'reilly Auto Parts. Quote Link to comment Share on other sites More sharing options...
Bassaholic Posted January 26, 2011 Author Report Share Posted January 26, 2011 Thanks for the help yall! Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted January 26, 2011 Report Share Posted January 26, 2011 On the shelf at any O'reilly Auto Parts. Or any Chevron gas station/mini-mart. Techron is THE BEST, you can not beat it. I recommned you use it on a regular basis, not just for winter storage. Add 1/2 bottle every so often UPON FILL UP (do NOT add it to a low tank). Phill Quote Link to comment Share on other sites More sharing options...
Hooper T Posted January 30, 2011 Report Share Posted January 30, 2011 I store her with a full tank and a gas stabilizer. I'm not sure if that's the same as a cleaner. I know I stored a 1/2 tank of gas for my outboard without a stabilizer and in the spring in had an inch of water floating on top. That's because of the new gas/alcohol mixture now days. The alcohol pulls moisture out of the air. +1 Quote Link to comment Share on other sites More sharing options...
gt350lp Posted February 1, 2011 Report Share Posted February 1, 2011 Or any Chevron gas station/mini-mart. Techron is THE BEST, you can not beat it. I recommned you use it on a regular basis, not just for winter storage. Add 1/2 bottle every so often UPON FILL UP (do NOT add it to a low tank). Phill Costco carries it...Techron Quote Link to comment Share on other sites More sharing options...
Bassaholic Posted February 1, 2011 Author Report Share Posted February 1, 2011 Well I tried the techron and it worked great!!! It played the game at first where it shows half a tank after I just filled up but then it slowly went to full and never threw a check engine light at me. I'v driven it about 100 miles so far and no problems. Im so happy, ill never buy a cheap fuel injection cleaner again! I will definitely use a stabilizer next time I store it. Quote Link to comment Share on other sites More sharing options...
